Tractor Talk Discussion Forum
Farmall 560
Dan in Illinois
05-07-2005 16:46:59
Help!!! Recently aquired a Farmall 560, however I don't have a owners manual yet. Can anyone tell me where the proper place is to add hyd/trans oil and when it is at the proper level?? Thanks in advance for any help!!
Dan
moline
05-07-2005 18:19:58
 Re: Farmall 560 in reply to Dan in Illinois, 05-07-2005 16:46:59
Hi Dan,if it is like my 460,there is a 3 bolt plate next to the gear shift.That is where I fill at.On the left side of the tractor in front of the clutch pedal about 1/2 way down the casting is a pipe plug.That should be the level.By the way,I am in east central Illinois.Wherebouts in this fine state are you from?Hope this helps,Moline
Dan in Illinois
05-08-2005 19:12:39
 Re: Farmall 560 in reply to moline, 05-07-2005 18:19:58
Moline, THANKS for the info. I an located in Jacksonville. The hydraulic pump on this tractor is a little noisy at higher rpm"s. Is that typical for these older models??? Again, thanks for the info!!
Dan
