Tractor Talk Discussion Forum
14.5 HP Briggs
R Cronce
05-07-2005 14:08:04
THis Lawn Mower wont crank over It acts like a compression release problem. Model #287707 Type0224-01 code961226ze We have tried 3 used starters and jumped it directy from a car battery. Is there a compression release on this engine or some other reason for it to come up hard? even with the plug wire off.
roscodog
05-08-2005 08:47:22
 Re: 14.5 HP Briggs in reply to R Cronce, 05-07-2005 14:08:04
The compression release won't work if the valves are set too loose. Try setting them to spec, it worked for me. Ross
tlak
05-07-2005 14:42:29
Take the plug out and see if it turns over.
R Cronce
05-08-2005 17:16:11
 Re: 14.5 HP Briggs in reply to tlak, 05-07-2005 14:42:29
Valve adjustment did the trick. Thanks.
