Tractor Talk Discussion Forum
Sickel Mower for a 140
Melvin Davis
05-06-2005 09:08:17
Still hoping that someone might can help me out with a model # for my mower. It is a rear mount that fits on the back of a 140. If you know the model and a source for parts it would be appreciated.
Thanks in advance.
DavidA
05-06-2005 09:52:55
 Re: Sickel Mower for a 140 in reply to Melvin Davis, 05-06-2005 09:08:17
I have a model 27 to mount behind my IH 140, I also have a belly mount, I think there are several mowers that fit these tractors. Any Case HI dealship should have almost any part needed. Knives and rock gards my be cheaper from after market sources.
Melvin Davis
05-06-2005 15:55:21
 Re: Sickel Mower for a 140 in reply to DavidA, 05-06-2005 09:52:55
David
Thanks for your reply. Can you help me determine if my mower is the same Model as yours. Im trying to put a model number on it so that I can have a little better info when I go to the dealer.
Mine bolts up on the rear w/six bolts, three on each side. It has a short drive shaft with a belt that actually dives the sickel. It has a wooden pitman arm. Would there be a chance you could send me a picture or maybe compare some part numbers on various parts. Again thank you.
Melvind
