Tractor Talk Discussion Forum
Ford 5000 will 2250 IH ldr fit
Kraig
05-04-2005 14:13:32
I have a Ford 5000 and was wondering if a International 2250 Loader fit without any major fabrication? Thanks.
Ken Macfarlane
05-05-2005 05:44:55
 Re: Ford 5000 will 2250 IH ldr fit in reply to Kraig, 05-04-2005 14:13:32
The 2250 fits a lot of IH and Case tractors and is very popular, you could probably trade it at a dealer for a ford loader for your tractor. The ford loaders are much less popular around here.
JiminIA
05-04-2005 19:20:36
ANything will fit with a welder and a torch. And of course the time to mess with it. :)...Jim
wolfmantractor
05-04-2005 18:12:57
If you can measure the width of say an IH 684 or 574 (at their mounting plates for loader frame) , then measure any mounting frame areas on your Ford; If widths are nearly the same, the most you should have to do is drill a couple-four at most per side- in the mounting frame(s). If Ford is a bit narrower, shim. If wider, punt.
RickB
05-04-2005 17:27:37
The loader is probably a pretty good match for a 5000. Coming up with proper mounts will undoubtedly require major fabrication.
