Tractor Talk Discussion Forum
AILLS D17RUNNING PROBLEM
SETH S
05-04-2005 06:44:49
I have a D17 that had a flooding. So I replaced it with a rebuild. Even with it flooding out the carb, it still did not seem to want to run with out being choked. When I replaced the carb. wth the rebuid one it still will not run with out being choked. Any. help ? THANKS.
Mike (WA)
05-04-2005 08:19:09
 Re: AILLS D17RUNNING PROBLEM in reply to SETH S, 05-04-2005 06:44:49
If you have to choke it, you have too much air for the amount of fuel available. Old hit one of the possibilities- not enough fuel. The other is too much air, from a vacuum leak- meaning a cracked intake manifold or blown manifold or carb gasket. Push in the choke until it will barely run, then spray WD-40 around the manifold area- if it runs better, its a vacuum leak.
wolfmantractor
05-04-2005 18:24:01
 Re: AILLS D17RUNNING PROBLEM in reply to Mike (WA), 05-04-2005 08:19:09
Mike's probably right on.
old
05-04-2005 07:48:05
Sounds like you have a problem with the fuel tank/sediment bowl being clogged or a clogged fuel line.
