Tractor Talk Discussion Forum
4430 noise
r2d2
05-04-2005 06:09:42
My planting tractor 4430 makes an awful noise when using alot of hydraulics as with the planter. Use a hydraulic driven solution pump and other scv jobs as lifting and marker fold. The noise seems to be underneath the cab possibly inside the rearend case.What could this be???
thurlow
05-04-2005 10:37:47
 Re: 4430 noise in reply to r2d2, 05-04-2005 06:09:42
Just behind the left battery, there is a ..... ...for want of a better description..... .hydraulic junction box; three hydraulic lines in/out. Held to housing with 2 bolts; if those bolts vibrate loose/out, it sets up a gosh-awful vibration/noise.
r2d2
05-04-2005 19:59:56
 Re: 4430 noise in reply to thurlow, 05-04-2005 10:37:47
Thurlow, That is exactly what it was. Thanks, Only it was on the right side . Broken off bolt in that junction box.
thurlow
05-05-2005 04:53:40
 Re: 4430 noise in reply to r2d2, 05-04-2005 19:59:56
You'd think by now I could tell my right from my left; couldn't believe it when I went back and read my post; I'm probably eventually gonna have to tap the one on mine out to the next bigger size; threads are worn and it wants to shake loose every few months; might try some lock-tite first..... ..
rotten robert
05-04-2005 18:50:18
And then it goes "Kerplowie" and dumps ALL the the hyd fluid faster than you can imagine.
