Tractor Talk Discussion Forum
steel wheels for john deere A
Bryantt Bolduc
04-30-2005 10:09:41
Say i buy a pair a rear steel wheels for my unstyled A. They don't have the hubs in them but are meant for 10 spline hubs, Can I use the 10 spline hubs off of my rubber wheels?
JPatton
05-01-2005 07:23:33
 Re: steel wheels for john deere A in reply to Bryantt Bolduc, 04-30-2005 10:09:41
Bryant - You MIGHT be able to use your current hubs. Are both sets of wheels set up for the "replaceable" hubs? These are the one with a clamp or collar that slips onto the hub and uses 3 bolts to tighten it down. There ar 6 bolts that secure the wheel to the hub. If so, you can interchange the wheels using your hubs. This type hub was used on steel wheels, flat spokes with rubber and the heavy cast iron wheel centers for rubber tires. The other 10 spline hub just slides onto the axle and the wheel fits over the tapered portion of the hub to act as a clamp. These also have 6 bolts that secure the wheel to the hub, but remember there is no clamp. These are interchangeable only with that type of wheel. This style hub was not available for use with the heavy cast center but was used wilth the F&H style flat spoke and round spoke wheels for both rubber and steel.
Hope this helps.
J
maark
04-30-2005 12:50:08
yes.
