Tractor Talk Discussion Forum
broken post
B.A. Terry
04-30-2005 08:04:40
Just a quick question. Was taking a cable off a 12V battery on the tractor and the post broke, it is loose. Is the battery still usable or time for a trade in?
Farmered
05-01-2005 06:24:06
 Re: broken post in reply to B.A. Terry, 04-30-2005 08:04:40
Don't chance it. If the post is loose from the plates it could spark internally and when it explodes you will have acid all over your body.
Speaking from experience. Lucky for me it was in a good battery box. Ed
dr.sportster
05-01-2005 07:58:25
 Re: broken post in reply to Farmered, 05-01-2005 06:24:06
Maybe it is a bad idea when you mentioned battery explosion I started rethinking my repair suggestion.
Maark
04-30-2005 12:52:20
It will probably still work. You will need to seal that post to the case though. Use silicone out of a tube. It's acid resistant.
Allan in NE
04-30-2005 11:56:19
T.A.,
You probably just broke the case and not the post/plate attachment.
It should still work as it always did, but you have to be careful and remember that the post isn't anchored anymore.
Allan
dr.sportster
04-30-2005 11:26:49
Cmon, be cheap get out the J-B weld and at least give it a try.If my battery had some J-B weld blobs on it and it still started the tractor I wouldnt care.
Coloken
04-30-2005 11:21:29
Still under warentee? I once got some use out of one by drilling small hole in stub and screwing in a metal screw with connector. Not good enough for a starter though.
Kenny
Yes
04-30-2005 08:09:49
Trade in.
