Tractor Talk Discussion Forum
Jd 450 crawler
grkoch
04-29-2005 13:12:32
I'm looking for a used motor in running condition for JD 450 crawler. If anyone knows where or who I can contact to find one it would be a big help
jdemaris
04-29-2005 15:12:50
 Re: Jd 450 crawler in reply to grkoch, 04-29-2005 13:12:32
You can expand your search to several farm tractors that have engines that will fit - e.g. the 2020 and a few others. 2510 or 2520 I also think will fit. I don't know which 450 you have, they use three or four different engines, but they all have the same bolt pattern. If buying a used engine, make sure you check for hot oil pressure at idle speed and loose balancing shafts.
grkoch
04-29-2005 15:30:45
 Re: Jd 450 crawler in reply to jdemaris, 04-29-2005 15:12:50
Sorry should have put in more imformation regarding the motor. It is a diesel, 4 cylinder don't know the size or cc.
jdemaris
04-29-2005 19:22:31
 Re: Jd 450 crawler in reply to grkoch, 04-29-2005 15:30:45
The 450s used a 3.8" bore engine, a 4" bore with standard top rings, a 4" bore with Keystone top rings and turbo, and maybe more changes as the series got newer.
