Tractor Talk Discussion Forum
need to find serial # 0n ford 901 powermaster
jimmy jim
04-27-2005 10:32:17
I need to know where to locate the serial # on a ford 901 powermaster(gasoline). I have also looked for the model # and what i found above two mounting holes and below air cleaner on the left side hand stamped is 741 over 5798. any help would be appreciated. thank you
tlak
04-27-2005 10:41:45
 Re: need to find serial # 0n ford 901 powermaster in reply to jimmy jim, 04-27-2005 10:32:17
If these numbers you found are on the trans right behind the starter(same location you described) you do not have a 901. You have a series 701, model 741 with the serial # 5798.
Should be a 4-speed with non-live pto.
jimmy jim
04-27-2005 11:17:41
 Re: need to find year of ford 701 powermaster in reply to tlak, 04-27-2005 10:41:45
how do i find out the year and horsepower of this tractor? ford 701 model #741 serial #5798
tlak
04-27-2005 11:41:46
 Re: need to find year of ford 701 powermaster in reply to jimmy jim, 04-27-2005 11:17:41
I think these came with the smaller 132 ci instead of the bigger 800 series engine. About 32hp.
Somebody will come along and post the site that you can look up the sn on. I cant find it right now.
There is a sn/year button at this site down the left column but it doesn't make sense to me.
Steve (Magnolia, TX)
04-27-2005 12:21:13
 Re: need to find year of ford 701 powermaster in reply to tlak, 04-27-2005 11:41:46
I believe that you're right (I could, hwever, be wrong too).
I think that the 701 was to the 601 what the 901 was to the 801... in other words, the 701 is a 601 only row-crop style (higher clearance, and a good chance that it's a tricycle).
Of course, if that's true, then your 701 (OK, 741) would be a Workmaster rather than a Powermaster...
Steve
