Tractor Talk Discussion Forum
polorize
jon small
04-27-2005 05:49:23
how do i polorize my farmall h
Bigdog
04-27-2005 12:17:46
 Re: polorize in reply to jon small, 04-27-2005 05:49:23
The generator is polarized by a momentary application of battery voltage to the generator armature. If your H is still the stock 6 volt positive ground system this can be accomplished by briefly touching a jumper wire to the "Batt" terminal and the "Gen" terminal on the voltage regulator. You should see a slight spark when you do this. This must be done with the engine shut off.
