Tractor Talk Discussion Forum
tractor standard ballast
G. R. Ambalkar
04-25-2005 04:34:21
I want know about what is the standard ballast on tractor.
buickanddeere
04-25-2005 04:40:28
 Re: tractor standard ballast in reply to G. R. Ambalkar, 04-25-2005 04:34:21
Bias ply tires pulling a heavy draft load with a 2WD ay 3 to 5 mph. 115 to 145 lbs per pto HP. At rest/parked, 35% of weight on the front axle.
genep
04-25-2005 05:23:59
 Re: tractor standard ballast in reply to buickanddeere, 04-25-2005 04:40:28
I'm going to ask a dumb question here, but does the ballast you're speaking of include the weight of the tractor? +/- 130# per HP sounds like a lot to add to a tractor. Thanks,
Gene
buickanddeere
04-25-2005 07:51:08
 Re: tractor standard ballast in reply to genep, 04-25-2005 05:23:59
Total tractor weight. Tractor,driver, fuel and ballast combined. Stats are from Firestone Tire engineers after spending thousands of hours and hundreds of thousands of dollars. I'll take that test data over "Buba's" opinion down at the diner.
jddriver
04-25-2005 15:31:54
 Re: tractor standard ballast in reply to buickanddeere, 04-25-2005 07:51:08
After all one engineer would never point out that their may be some intelligince some other that their sterile controlled conditions cause us dumb farmers dont know nuthin
Oliver
04-25-2005 08:57:58
Now wait a minute, Bubba knows ballast!!!
earlschieb
04-25-2005 09:14:06
 Re: tractor standard ballast in reply to Oliver, 04-25-2005 08:57:58
Thats cause he is sitting on it.
