Tractor Talk Discussion Forum
How do I adapt a manure bucket for handling fill?
Rod in Smiths F
04-14-2005 17:29:37
I have a Freeman loader with full hydraulics on a MF 35. Today I asked a guy to bring a load of earth fill so that I can start filling in some holes left in the barnyard after a Hy-Hoe lifted out about 50 cubic yards of large stones called "hardheads".
These cavities sneak up on me when bush-hogging, and I'd like to reduce the adrenaline level of the job, if possible.
The loader as it is currently set up would do a good job of sifting out any stones in the fill, but that would be about it. Are there any specifications for a gravel plate?
Thanks,
Rod
Farmered
04-16-2005 03:02:11
 Re: How do I adapt a manure bucket for handling fi in reply to Rod in Smiths Falls, ON, , 04-14-2005 17:29:37
Those "hard heads" could be valuable. When I lived in NY State I had a stone mason build us a fireplace using split rock. I found that if you study those smoth round boulders that they have a grain. If you hit them in the right spot with an eight pound sledge they will pop open revealing a beautiful crystaline surface. The ones I had varied from gray to pink on the inside. Then again I guess what made them valuable was the labor that went into the project. Ed
04-16-2005 13:22:23
 Re: How do I adapt a manure bucket for handling fi in reply to Farmered, 04-16-2005 03:02:11
Yes, they have a grain, but what you don't want to find is one of about 1 yard sitting 5" above the proper grade for a septic tank. I can tell you from experience that an 8lb sledge has no effect whatever on a partially buried hardhead.
Out of the ground the rocks are often pretty: I've delivered the odd trailer load from the quarry next door to rock garden owners.
I worked with an old guy one summer who used to split hardheads for a living, upline of a crusher. He used a 30lb. sledge.
Don L C
04-14-2005 17:55:22
Rod --- I would check around and see if they can be had from a dealer....I think what you need is just a solid plate that fits over the manure tongs and turned up the sides to match the manure bucket.....it could be bolted on...
Allan in NE
04-14-2005 18:06:57
 Re: How do I adapt a manure bucket for handling fi in reply to Don L C, 04-14-2005 17:55:22
Rod,
Like Cowman says, they are nothing more than a 1/8" steel plate with loops welded on that the teeth go thru.
Here's a picture of mine.
Allan
third party image
04-14-2005 18:31:44
 Re: How do I adapt a manure bucket for handling fi in reply to Allan in NE, 04-14-2005 18:06:57
Thanks for the picture. That plate looks as if it has had an interesting service life.
Would U-Bolts work to hold the plate on? I don't weld (embarrassed grin).
Allan in NE
04-14-2005 18:45:34
 Re: How do I adapt a manure bucket for handling fi in reply to Rod in Smiths Falls, ON, , 04-14-2005 18:31:44
Hi Rod,
Yep, I put new teeth in the head, now I gotta straighten the darned plate (before someone else gets to see it). :>)
Sure U-bolts would work. All they have to do is hold the plate up to the teeth on the outside edge. But remember, the heads will be digging into your material underneath of the plate (shouldn't matter, tho).
See the little tabs on the other side? They hold the back side of the plate bolted onto the bucket.
Allan
04-14-2005 18:53:05
 Re: How do I adapt a manure bucket for handling fi in reply to Allan in NE, 04-14-2005 18:45:34
Why does the plate go under the bucket?
Allan in NE
04-14-2005 19:04:03
 Re: How do I adapt a manure bucket for handling fi in reply to Rod in Smiths Falls, ON, , 04-14-2005 18:53:05
Mine is mounted under the teeth, then those little tabs at the back, hook over the top of the bucket flange.
Don't think it really matters how a guy sets 'er up.
Allan
Nebraska Cowman
04-14-2005 17:52:01
most anything you find lying around will do. i think the plate on my Farmall M is 1/8 just and old rusty plate I found and put some clips to hold over the teeth. On mine the plate sets back about 6 inches from the ends of the teeth, gives me some bite for digging and then I need the teeth sticking out for handling hay. i never take the plate off.
