Tractor Talk Discussion Forum
Jd 60 wheels
David moore
04-12-2005 15:40:18
O.k how do you set the wheels in on a 1953 john deere 60 Thanks David
Maark
04-13-2005 07:16:48
 Re: Jd 60 wheels in reply to David moore, 04-12-2005 15:40:18
Loosen the three large bolts, tighten the two smaller inside ones until the sleeve comes loose. Then turn the pinion screw that sits out sideways on the cast wheel, you may have to use a sledgehammer on the end of the axle to get the wedge loose.Doesn't hurt to soak the whole area with penetrating oil.
