Tractor Talk Discussion Forum
JD 70
Boyd Nelms
04-12-2005 10:04:41
Does anyone know what type of oil should be used in the power steering pump in a JD 70.
Also which cylinder is the #1 cylinder.
Thanks
CLW
04-12-2005 22:23:23
 Re: JD 70 in reply to Boyd Nelms, 04-12-2005 10:04:41
Boyd, Deere has a special PS fluid for the 2 cyl. It is the one fluid you should not sub. for any longer than you just have too.
CLW
j cook (iowa)
04-12-2005 15:44:18
John Deere AF2235R Power Steering oil, available at your dealer!
Mike M
04-12-2005 10:36:50
#1 is the left hand or fylwheel side. You can get the right power steering fluid from your JD dealer. If you are in a pinch some hy-gard or atf would be better than nothing.
