Tractor Talk Discussion Forum
O.T Beef jerky
Leo B
04-10-2005 19:10:22
My whole family loves beef jerky. I was wondering if anyone had directions to make it so I can make my own? Any help would be appreciated.
RayP(MI)
04-11-2005 17:03:44
 Re: O.T Beef jerky in reply to Leo B, 04-10-2005 19:10:22
My recipe is very simple - Slice meat in strips. Roll in mixture of half salt, half granulated sugar. Smoke in a Brinkman smoker until you decide it's done to your satisfaction. My Brinkman is charcoal fired, and I throw in a handful of cherry or apple twigs, or wet cherry, hickory or apple wood chips to provide the smoke. Delicious!
Steve (Magnolia, TX)
04-11-2005 10:50:43
I get this little catalog every year that has all kinds of supplies (sausage, jerky, taxidermy, etc.). I haven't ordered from them (yet), but it all looks pretty good...
Here's their website....
HTH
Steve
Mike7468
04-11-2005 10:06:49
I use a seasoning mix called Hi- Country they have several different types of seasonings start with the original, I use a dehydrator which takes between 10-16 hours.
buickanddeere
04-11-2005 09:04:38
I enjoy the stuff but have to floss the stingy bits out from between the teeth. Staying out of confined spaces for 8 to 24hrs after jerky consumption is suggested.
Jamie Estes
04-11-2005 08:25:41
What does this have to do with tractors?????
Leo B
04-11-2005 17:39:39
 Re: O.T Beef jerky in reply to Jamie Estes, 04-11-2005 08:25:41
I always chew jerky while driving my tractors and I didn't know of a better place to ask and furthermore the reading has been interesting
JonwithanM
04-11-2005 06:15:54
Saw your post and thought I'd throw in my 2cents.
I make a lot of Deer jerky but beef is cured the same.
You have to have lean meat, trim as much fat as possible because fat turns rancid and tastes bad!
If your meat is almost frozen it will slice better, try and slice about 1/4" slices or less.
Find Mortons curing salt. I found it at my local meat market. It is necessary to allow the salt to "soak in" for about 12 hours prior to starting the drying process. This kills bad bacteria because you are not cooking the meat you are dehydrating it.
Place your meat strips in a ziplock bag, I use 1 gallon size, for this size I add 4 tbsp soy sauce
4 tbsp worstishire sauce
2 tbsp curing salt
2 tbsp brown shugar
1 tpsp crushed red pepper
1tbsp italian seasoning
This makes alot of jerky, more than a conventional oven can handle. Adjust as necessary.
close the bag and knead it around real good.
Refrigerate 12 hours.
Now from here I have a 55 gallon smoker that works great. I use kabob stickers and let the strips hang down inside my smoker. But you can also put the strips in your oven.
Temprature is the key, you want it to be about 150deg and not over 180 deg. for about 5-8 hours depending on your thickness. If you use your oven you want to have the door cracked I used my meat thermometer to keep it cracked that way I can regulate the temp.
That's about it, It's a long process and mine is about half gone by the time it is finished!
Enjoy
Jon
AZ Jack
04-10-2005 20:26:14
A fiend of ours makes jerky out of hamburger-it is really good. If you want the recipe let me know and I will send it along. Jack
T_Bone
04-11-2005 01:33:46
 Re: O.T Beef jerky in reply to AZ Jack, 04-10-2005 20:26:14
Hi Leo,
Some of the best jerky I ever had was beef-a-lo jerky from Montana. The guy would slice them about 1/4" thick then dry them until stringy (chewy), not hard. Wow what a taste. Had a taste of black pepper, salt, and? brine.
Most all the recipies I ever seen was 60%salt and 40%brown sugar brine with a 24hr soak time. If smoked then 115� maximum with water soaked wood chips.
I worked with a guy that made jerky as a side job. He wouldn't tell much other than he used top serlion for meat. Pretty tasty tho. Been too long ago but 10lbs to 1/lb jerky? I know it shocked me when I heard the shrinkage rate. He was Mexican and I awlays kidded him about using those "special" peppers in his brine but it wasn't hot.
T_Bone
Dougs47B
04-10-2005 19:31:29
My son smokes his own beef jerky. He should be home later on and I'll ask him to help you. I am getting ready to do some painting on my 1947 Farmall B . Where is the best place to get the original color red? I have had a major job taking off 4-5 coats of paint. (No Rust) I will be finishing soon. Am going to sandblast the wheels as I think it would be easier. Then the fun part (painting) begins.
Jeff Oliver
04-10-2005 21:29:13
 Re: O.T Beef jerky in reply to Dougs47B, 04-10-2005 19:31:29
We usually get the best results getting the paint from a dealer although I will say this. Last time we painted a red one we had to paint it 5 times because we would paint part of it then come back the next day using the same material and it would come out a different shade. Wound up getting everything ready at one time and painting it all, every piece and bolt. Never had this problem with JD green paint and no one else I know of has had it with IH red, maybe it was a full moon?? LOL!
farmered
04-11-2005 01:50:27
 Re: O.T Beef jerky in reply to Jeff Oliver, 04-10-2005 21:29:13
Don't laugh but your John Deere dealer has paint that is just a perfect match for the IH red. I used some on my Farmall 130 with good results.The Hi Temp aluminum spray is a better match for wheel rims than the regular aluminum and doesn't rust through as fast. Try it, you'll like it. Ed
