Tractor Talk Discussion Forum
Farmall 706 not running right
Cory A.
04-10-2005 13:51:57
We finally got the 706 running but it runs really bad. The timing is off a little but that doesn"t seem to be the problem. It will run ok for awhile but then it bogs down and dies. I think its sucking air and not getting enough gas but I"m no expert. The only way we can keep it running is with the choke on. Any help would be apprecited! Thanks
ed1
04-11-2005 10:39:34
 Re: Farmall 706 not running right in reply to Cory A., 04-10-2005 13:51:57
try running it with the gas cap off. I'll bet the vent in your gascap is plugged.
I Like Case
04-10-2005 18:12:04
If it runs with the choke on, it is finding air somewhere. Get out the spray can of carb cleaner(please don"t use the ether)and start spraying along the carb and intake system until you see-hear- an RPM change. That will be the source of your leak.
Farmall Teen
04-10-2005 17:05:27
Sounds like the carberator is out of line. Might want to check it, but that is what I think, could be wrong
Cory A.
04-10-2005 20:14:23
 Re: Farmall 706 not running right in reply to Farmall Teen, 04-10-2005 17:05:27
We had the carb rebuilt and it seems to be working fine.
Farmered
04-11-2005 02:16:14
 Re: Farmall 706 not running right in reply to Cory A., 04-10-2005 20:14:23
Don't assume that because you had the carb. rebuilt that that is not where the trouble is.
Check: float level proper gasket between carb top and bottom vacuum leak between carb and manifold needle valve adjustment- dirt in fine holes in carb. fuel filter - strainer - line manifold gaskets
