Tractor Talk Discussion Forum
Long Tractor Hydrolics
Harold Lee
04-10-2005 06:54:21
The 3 pt hitch lift on my LONG 445 is very eratic. It will lift a little, stop, lift some more, stop, and lift some more. The power steering is stiff and my 3 pt hitch log splitter moves a little, stops, moves a little more, stops and moves some more. The whole time the hydrolic system whines. Any help in trouble shooting this problem will be greatly appreciated.
Thanks!
heiko
04-10-2005 07:21:12
 Re: Long Tractor Hydrolics in reply to Harold Lee, 04-10-2005 06:54:21
sounds like your tractor wants some hydraulic-fluid or a new filter for it...
should work then...
espacially in your LONG tractor there a LONG ways that require more oil...
Jim in NC
04-10-2005 07:11:24
I have a 445 and a 360. Here are some ideas. Check the level of hyd. oil with dipstick on top of transmission case. I use 30 wt ND in mine. See if the filter is clogged and needs to be cleaned. It is located in hyd. line on right side below the starter. I soak mine in gas then blow with compressed air. Make sure you do not lose the rubber washer on the filter and the o ring in the end plug. If very dirty, you may need to change the oil. There are 2 drain plugs-under transmission and rear end. There are some other parts of the lift that can be checked, but you must have a good supply of clean oil and a clean filter for both the ps and lift to work properly. Good Luck
