Tractor Talk Discussion Forum
solenoid question
willy p
04-08-2005 19:10:30
On a JD 2040 try to crank it and the solenoid just clicks keep hitting the switch and it finally engages, put a test light to the wire from the switch to the solenoid and it lights up every time,put the light from the post from the solenoid to the starter and it lights up some of the time,is this the solenoid? I just put a new solenoid on it and it does the same thing,is the new solenoid bad? Thanks
Davis In SC
04-08-2005 20:07:10
 Re: solenoid question in reply to willy p, 04-08-2005 19:10:30
On a 245 MF, It was a monthly thing to replace solenoid..... I finally took all the wires loose & sanded contact areas, & added another ground lug. I have not had any trouble since.....
Joe Bloggs
04-08-2005 19:29:43
if you replaced the solenoid and still have the same proble. it could be the switch is not providing enough voltage to the solenoid. make sure its getting the full 12v some will work down as low as 8v.
deereford
04-08-2005 19:14:11
I had the same problem with a JD 2940 and discovered the soleniod plunger was gummy and sticky. After cleaning the gum out it has worked perfectly since. Good luck. deereford
