Tractor Talk Discussion Forum
OT:95 Chevy truck
52 A Boy
04-08-2005 17:28:10
I have a friend that has a 95 chevy pickup and about 5 months ago he got a rebuilt 350 put in it, but he said that the starter is starting to drag now, but it didnt before he took it in to get the new engine. I was just wondering what yall might think some of causes might be. Any help would be appriciated
52 A Boy
dr.sportster
04-09-2005 06:28:47
 Re: OT:95 Chevy truck in reply to 52 A Boy, 04-08-2005 17:28:10
Sometimes you have to shim the starter any auto parts sells a pack of various thickness starter shims for a couple bucks.
Allan in NE
04-08-2005 18:10:45
I've always made it a practice when installing a new engine to replace all hoses, belts, the distributor/wires, the battery, the starter and the alternator. They get tired too.
Allan
Mike M
04-08-2005 18:39:33
 Re: OT:95 Chevy truck in reply to Allan in NE, 04-08-2005 18:10:45
I'm with you Allen I always fix all that stuff too. How do these guys expect to start a rebuilt engine with junk starter. That new engine will crank alot harder than an old worn out one with no compression.
MarkB_MI
04-08-2005 17:58:08
Check the starter mounting bolts. They have a tendency to loosen on Chevys.
buss
04-08-2005 19:30:50
 Re: OT:95 Chevy truck in reply to MarkB_MI, 04-08-2005 17:58:08
also some 350 have to add ashim under starter bracket . but would think bearings and brushes could be culprit
toolman
04-09-2005 00:57:46
 Re: OT:95 Chevy truck in reply to buss, 04-08-2005 19:30:50
check and make sure mounting bolts are tight and all elextrical connections are clean and tight, other than that id start looking at fly wheel andbendix tooth match up.
