Tractor Talk Discussion Forum
Backhoe attachment
krharris
04-08-2005 08:28:45
I have a Ford 345c and want to hook up a backhoe. Do I need a pto hydralic pump or can I run it from the tractors hydralic system. If it will run from the tractors system where do I connect it. Thanks
JMS/MN
04-09-2005 09:05:32
 Re: Backhoe attachment in reply to krharris, 04-08-2005 08:28:45
The manufacturer of the backhoe should provide requirements as to gpm flow, and pressure. Compare those needs to what your tractor system puts out. Likely to need an extra pump. 3ph backhoes typically use a pto pump, but you may be able to mount one in front of the crankshaft pulley.
