Tractor Talk Discussion Forum
Onan Performer 16 problems
fontes22
04-07-2005 09:47:12
This Onan engine runs a pecan sprayer. I have replaced gasoline, spark plugs, plug wires and coil, and it still will not run. There is a spark from the plugs too. The engine cranks and "wrrrr wrrrrs" but no starting up. Maybe the mangneto and the timing??? It is model # P216G-I/11252G,2 cycle engine, if that helps. Desperate for answers, any help is appreciated!!
NC Wayne
04-07-2005 18:31:46
 Re: Onan Performer 16 problems in reply to fontes22, 04-07-2005 09:47:12
Ok, if you've checked the electrical side and not found a problem and made sure it had good gas in it and it's still not running then it could be either lack of compression or a problem in the carb. Even if it's getting fire and has good gas it's not gonna run if there is a carb problem and the gas isn't getting into the cylinder. If the carb is good it still isn't gonna run if it doesn't have enough compression. Check your compression first, it's the easiest thing to do, and if it's good then move onto the carb. Those are the next things I'd check, beyond that it's hard to say what might be wrong without actually seeing it. Good luck
