Tractor Talk Discussion Forum
Ford Jubilee
thawkt
04-04-2005 21:49:43
I have a Ford Jubilee that has one of the sleeves loose in the block. I can place my fist inside the sleeve and rotate it. My question is will this lead to a loss of compression or will the head gasket cover the OD of the sleeve and seal it off? Also, If I was to replace the sleeve, are the OD's of the replacement sleeves the same OD's of the original sleeves? I know you can buy overbored sleeves which is overbored in the ID but what about the OD? Thanks.
Bob - MI
04-05-2005 12:25:32
 Re: Ford Jubilee in reply to thawkt, 04-04-2005 21:49:43
You may want to post this on the 9n/2n/8n board. There have been lots of questions over there about loose sleeves. If you search the archives you will find some that have used epoxy to hold new sleeves in place.
