Tractor Talk Discussion Forum
Lawn roller from 55 gal drums?
Bob Quale
04-04-2005 17:02:31
I want to make a lawn roller out of two 55 gal drums. Has anyone done this, and will it work? Will the ridges on the drum cause trouble? It will only see little use, fixing frost heave damage, and to roll freshly seeded areas.
Thanks for any help you can offer.
Bob
Dieselrider
04-04-2005 19:41:14
 Re: Lawn roller from 55 gal drums? in reply to Bob Quale, 04-04-2005 17:02:31
I used a 30 gallon grease drum for behind the cub. The thing weighs over 600# which is plenty heavy for on the yard. yes you do see the ridges but they fade away with the rains and such and they do not tear up the yard much. Using the card board drum would be a good idea too.
oleblu
04-04-2005 18:12:36
My lawn roller was made using a cardboard drum. They have no ridges. We put a pipe through the center of the ends and let it stick out about 6 inches on both ends. When the cement dried in the drum, just needed to peel off the cardboard. I built a toung and attached it the the pipe ends.
Sid
04-04-2005 17:25:56
I have seen it done with just on drum. It seemed to worke alright. What the ridges did mear while turning on some area he had seeded he just raked them out.
Yes........
04-04-2005 17:16:57
the ridges will cut into lawn while you are turning. Try finding an old galvanized hot water tank.
Bob Quale
04-04-2005 19:28:58
 Re: Lawn roller from 55 gal drums? in reply to Yes........, 04-04-2005 17:16:57
I looked for an old water heater but was unable to find one at this time, I have passed up a million of them in the past, go figure. Any way, if I were to make one out of concrete, what diameter should it be? I want to make it six feet long? and just in case, is there a water heater that would have been that tall?
Thanks for the help!! I don't want to wreck what lawn I have!
Bob
