Tractor Talk Discussion Forum
JD 37 MODEL A
RONNIE STOUT
04-04-2005 09:43:40
Could some one tell me where the timing mark is on a 37 model A,the fly wheel is plainly marked but not the tractor.IM thinking its 3 0 clock?Thanks in advance..... ....good luck
Mike M
04-04-2005 10:39:22
 Re: JD 37 MODEL A in reply to RONNIE STOUT, 04-04-2005 09:43:40
I think you are right somewhere around the 3 o clock on the trans. case side cover you should find a line cast in it or a lip if it's tin.
RONNIE STOUT
04-04-2005 11:28:20
 Re: JD 37 MODEL A in reply to Mike M, 04-04-2005 10:39:22
THANKS MIKE I BELIEVE I FOUND THE PROBLEM,I THINK I HAVE A BROKEN IMPULSE COUPLER.THE TRACTOR IS MIGHTY HARD TO START,AND WHEN I WENT THRU THE TIMING PROCESS I DID NOT HEAR THE AUDIBLE CLICK AT THE MAG.GUESS ILL PULL IT OUT .IS IT APPER4ENT WHEN THEY ARE BROKE?THANKS FOR THE HELP.
Mike M
04-04-2005 11:55:16
 Re: JD 37 MODEL A in reply to RONNIE STOUT, 04-04-2005 11:28:20
It may just be gummed up,or could have a broken spring. When off hold it upright (careful where your hands are it might zap you)then rotate the back of the mag,impulse coupling,counterclockwise it should have a pawl come out and catch on a tab then you should feel spring tension build up then it should let go with a snap.
