Tractor Talk Discussion Forum
pressure cleaner basics????????????
BSer
04-03-2005 15:47:45
I"m in a situation where I need to clean a machine miles from the shop. Will a piston type pump operate on water that is gravity flowed from a tank?
Mattlt
04-04-2005 06:50:49
 Re: pressure cleaner basics???????????? in reply to BSer, 04-03-2005 15:47:45
If it doesn't work, all you'd need is one of those cheapy drill-operated pumps between the tank and the pressure washer. That should provide enough flow/pressure.
Bob Whitmoyer
04-03-2005 17:51:43
Hi Should not be a problem, I have a gas powered pressure washer , on which I mounted a 5 gal. tank for soap, hot water, solvents (pump safe ones) etc, its hooked -gravity feed, to the inlet with a valve for switching from the garden hose back and forth. Works great..
Enjoy spring
Bob
Farmall Teen
04-03-2005 16:26:32
I think it will work if you had it following freely so that the pump can get the water
lucasss
04-04-2005 16:58:56
 Re: pressure cleaner basics???????????? in reply to Farmall Teen, 04-03-2005 16:26:32
have used several different kinds of pressure washers just hooked up to a water tank. lucas
