Tractor Talk Discussion Forum
JD STX46 - snow thrower attachment
newbie_sk
03-30-2005 19:17:10
Can someone please tell me if an JD STX46 model lawn tractor can be fitted with a snow blade or a snow thrower? If yes, what models are suitable? I know this model of the tractor is kinda out-dated..but I need some help with it.
Sloroll
03-30-2005 19:28:02
 Re: JD STX46 - snow thrower attachment in reply to newbie_sk, 03-30-2005 19:17:10
Believe me I'm not trying to be snooty, just been there. I am sure you can get a blower or blade to fit your tractor. It will be cheaper to buy a nice walk behind blower than to payfor, retrofit and work a blower or blade on that little tractor. You will need weights and chains too or it is completely helpless. If you get snow behind the blade or blower you are dead in the water too. If you raise off your seat for any reason (there are a lot of them) the engine dies and you will get frustrated. A cab is very helpful on tractor a blower because you just sit there in the cold with snow blowing on your face and up your pant leg. With a walk behind at least you are moving and warmer. It is much harder to get in a futile stuck position and really is so much more covenient. That is just my opinion on it. I am sure others will vary. Regardless good luck and I hope you really never have a huge snow to deal with! Bill
Brian in NY
03-31-2005 06:41:44
 Re: JD STX46 - snow thrower attachment in reply to Sloroll , 03-30-2005 19:28:02
absolutely right Slo.....the walk behind will be a much better alternative for snow removal, will be cheaper and more convenient in the long run.
And you don't need a monster either...a midsize machine will be fine...just don't get a single stage push machine unless your driveway completely smooth, flat and you don't get much snow.
Right now you can get a great deal on snowblowers anywhere they sell em....except maybe JD or Toro dealers.
