Tractor Talk Discussion Forum
JD GW TRACTOR FRONT END
SCOTT BONTRAGER
03-27-2005 19:38:05
I"EM LOOKING IN TOO BUYING A GW TRACTOR . BUT THE OWNER WANTS TO KEEP THE WIDE FRONT AXLE THAT IS UNDER THE TRACTOR NOW .THE TRACTOR HAS THE SPLIT FRONT END . I WAS WOUNDERING IF THE SINGLE FRONT END ON A MODEL A WOULD WORK ON THIS MODEL TRACTOR . ALSO NEED HELP FINDING A FULL SET OF SHEET METAL FOR THIS TRACTOR.
xragman
03-28-2005 07:05:13
 Re: JD GW TRACTOR FRONT END in reply to SCOTT BONTRAGER, 03-27-2005 19:38:05
scott. unusal last nameyou have. are you related to paul B around richardson-garland tex.?
edchainsaw
03-27-2005 21:44:25
as and owner of one of those type GW's
I know the wide front from an A is not the same.. but I think the single narrow would be..
and A's widefront can be made to work on a split pedestle G as I have seen LOTS of them done that way. They are not the same..
I am thinking the A single tire might have a smaller tire.. other than that I would think there might not be any difference in it.
