Tractor Talk Discussion Forum
300 farmall utility hydraulics
rick baker
03-26-2005 13:03:41
does the 300 utility have a hydraulic filter? if so where is it? cant get any oil to my hyd. pump
Ibby
03-27-2005 03:35:52
 Re: 300 farmall utility hydraulics in reply to rick baker, 03-26-2005 13:03:41
There's also a filter INSIDE the pressure regulator block. It looks like a hydraulic valve, but with no handle. Remove it from the tractor, take off the front cover and it's screwed into there. Mine plugged and blew the whole system!
rick baker
03-27-2005 11:08:35
 Re: 300 farmall utility hydraulics in reply to Ibby, 03-27-2005 03:35:52
thanks for the info..will pull that cover & check it! thought my pump was bad& after checking prices, mounted a front pump off the crankshaft,altered the plumbing to use the original valves& sump.I was disgusted when it still would not work. i have now removed that screen completely & installed spin on filter assembly & it now works great! also replaced old mechanical steering with full hydraulic orbital steering,used old ford car pump& hydraulic cyl. from tractor supply...think about that for awhile!
TDK
03-26-2005 17:30:58
You'll have to remove the hyd. reservoir under the seat. A fine screen filter is fastened to reservoir top.
rick baker
03-26-2005 18:59:04
 Re: 300 farmall utility hydraulics in reply to TDK, 03-26-2005 17:30:58
thanks, afraid you were going to say that.what a way to run a railroad huh?
JOSSETTE
03-26-2005 19:11:33
 Re: 300 farmall utility hydraulics in reply to rick baker, 03-26-2005 18:59:04
thats what the U stands for ----if you turn the U upside -what do you see- U assuming the position
JOSSETTE
03-26-2005 13:29:55
under the seat
rick baker
03-26-2005 19:04:34
 Re: 300 farmall utility hydraulics in reply to JOSSETTE, 03-26-2005 13:29:55
thanks,why on earth would they put a filter in such a location?? o well a solution comes to mind..its called john deere
big fred
03-26-2005 21:21:14
 Re: 300 farmall utility hydraulics in reply to rick baker, 03-26-2005 19:04:34
It probably hasn't been serviced since it was new. Having to take that reservoir cover off once every couple decades ain't that big a deal. The filter screen has quite a large surface area, so it won't plug up very often.
Van in AR
03-26-2005 19:43:15
A soulution comes to mind and its John Deere? Sure, but be sure and get a new one because some of the ones the same vintage as your 300 are no more service friendly, some worse.
Van
