Tractor Talk Discussion Forum
Oil Filter
Jordan Bower
03-25-2005 06:28:02
Is there and oil filter on a VAC case tractor? it appears not but just making sure... Thanks
Ryan - WI
03-25-2005 07:51:23
 Re: Oil Filter in reply to Jordan Bower, 03-25-2005 06:28:02
The oil filter was an option on VAC's. If your tractor has one it will be mounted on the right hand side of the engine just above and to the left of where the distributor would go in (or goes in if you do not have a magneto). If you don't there will be a diamond shaped cover plate there with two bolts holding it in. You can simply add on a filter housing if you want. They shouldn't be too difficult to find.
Bubb
03-31-2005 23:10:26
 Re: Oil Filter in reply to Ryan - WI, 03-25-2005 07:51:23
I"ve been wondering about this too. I have a 1949 Case VAC, and it"s got no oil filter. I haven"t been able to find a filter housing. Do you know where I could get one?
Thanks.
