Tractor Talk Discussion Forum
how to check injectors?
vabill
03-22-2005 13:04:46
hi, i finally got a new head for my case/ih 385 3 cyl, diesel, 35 hp. i ground the valves & installed them & i installed the head today. is there a way to check the injectors before i install them? thanks bill
MSM
03-22-2005 15:27:20
 Re: how to check injectors? in reply to vabill, 03-22-2005 13:04:46
Easiest way is to take them to an injector shop and have them tested. They can check spray pattern,cracking pressure,and make any minor adjustments that may be needed. The shop I use only charges $5. ea. to check them,considerably cheaper than buying an injector tester for a one time use. When you did your valves did you check the set out dimension? If you just ground them and the seats,you may have a hard start problem, or low speed miss caused by the valves being sunk down in the head too far.
vabill
03-23-2005 09:45:04
 Re: how to check injectors? in reply to MSM, 03-22-2005 15:27:20
thanks for the reply. i didnt grind the valves, had someone do it for me. going to check around for a shop to check out the injectors. thanks again. bill
