Tractor Talk Discussion Forum
OT: How To Get Overspray Off?
Dave in GA
03-21-2005 04:18:48
This winter I've been painting various tractor parts in the driveway using cans of spray paint. Some of the overspray drifted onto a nearby car. It's not noticeable to the eye, but the car now has a sandpaper-like finish, particularly on the hood, roof, and trunk. Yesterday I tried rubbing some Pre-Kleano onto a fender and after exerting some elbow grease, was able to get the overspray off, leaving the car's finish smooth again. I probably need to go over the entire car this way. My question is, while the Pre-Kleano works, is there a better product or method for removing overspray without damaging the good paint underneath? I found that brake fluid works the best for removing overspray from windows, but it can't be used on painted surfaces as it will eat the paint.
Dan
03-21-2005 07:53:44
 Re: OT: How To Get Overspray Off? in reply to Dave in GA, 03-21-2005 04:18:48
A clay bar is the best. But, once I got some overspray on my 2003 Ford Cobra and the advice I got from a paint guy was to get a cotton rag, put some mineral spirits on the rag, then wipe the surface down until the overspray is off. You will need to re-wax your car, but this trick worked real well for me and required very little elbow grease. I was really surprised at how easily it came off.
Try it in a small area first - just to make sure...
Good luck,
Dan
chvet73
03-21-2005 07:12:25
Get a clay bar cleaner kit. You will be shocked at how much stuff it takes off.
Joe Crow
03-21-2005 06:33:29
One ounce of prevention
tlak
03-21-2005 08:29:15
 Re: OT: How To Get Overspray Off? in reply to Joe Crow, 03-21-2005 06:33:29
Seen a lot of tires painted. Only takes a couple minutes to protect them.
Galen
03-21-2005 05:36:00
I've used a litle "Goop" handcleaner on overspray. Then carwash.
Redmud
03-21-2005 05:33:59
Guys, you gotta watch what you rub on a clear coat paint job, or thats what the paint shop told me after I waxed my red Chevy truck. I now have a flat red paint job, it took about a month for the paint to turn flat after I waxed it. Sad part was, it didn't need waxing when I did it, I just needed something to do.
sammy the RED
03-21-2005 10:22:53
 Re: OT: How To Get Overspray Off? in reply to Redmud, 03-21-2005 05:33:59
I wax my clear coat paint twice a year.
Never got any "Flat" spots.
What did you do wrong ?
Redmud
03-21-2005 16:26:57
 Re: OT: How To Get Overspray Off? in reply to sammy the RED, 03-21-2005 10:22:53
Red, I don't remember what I used on the truck, the truck is an 82 GMC, and this happened years ago when it was 3-4 years old. I did show the body man what I waxed it with, he said I shouldn't have used it, he would have said the same thing if I had told him that I washed it with plain water. I always thought GM didn't put enough clear coat on it. I still have the truck, thinking about another red clear coat paint job on the old sucker.
Allan in NE
03-21-2005 05:03:43
Hi Dave,
Get a bottle of spray-on road tar remover from your local supplier.
By the time you can walk around that car with the spray bottle, the overspray will be laying on the ground. Rinse with a garden hose.
Allan
RustyFarmall
03-21-2005 04:40:19
I've done the same thing, the first thing you do is take it to the car wash, you'll be surprised at how much of the overspray comes off. Next, just a good wax, applied by hand and rubbed off by hand.
Buckeye
03-21-2005 04:36:19
I have some overspray on some tires I bought. Any advice on how to remove it?
Ray
03-21-2005 04:52:33
 Re: OT: How To Get Overspray Off? in reply to Buckeye, 03-21-2005 04:36:19
I use chemtool carb cleaner to remove overspray on tires,but if it"s old hard paint I"ve has to use the wire wheel on my grinder.
deadeye
03-21-2005 06:03:25
 Re: OT: How To Get Overspray Off? in reply to Ray, 03-21-2005 04:52:33
Just get some tire paint and paint the tires black. Miller Tire sells about the best I have seen. They have a website.. Won't rub off.. deadeye
