Tractor Talk Discussion Forum
Bobcat skid steer hydarulic oil question
Nellie
03-20-2005 04:19:41
I bought Bobcat 843 at a spring auction that had a slight electrical fire. Other than the bobcat dealer hydraulic oil what other hydraulic oil alturnatives do I have? I like the dealer, it is just the long drive. Will the common hydraulic oil found found in nearly every tractor etc. store be acceptable?
Big Mike
03-20-2005 09:46:52
 Re: Bobcat skid steer hydarulic oil question in reply to Nellie, 03-20-2005 04:19:41
In the 743 Bobcat at Work we use Motor oil. 10-30 I think is what the Book calls for.
cootbruce
03-20-2005 06:38:30
Go to this link and post...you may even find the answer by looking through the posts. Good site to have when you own a bobcat
Link
Good luck
SJ
03-20-2005 06:08:57
Im no expert but,I have been driving an older JD skidsteer at work for a long time and over the years weve put just about anything in it,even motor oil in a pinch,never seem to bother it,although this machine is used inside 99% of the time so I imagine extreme temperature might be a factor if your not using oil up to specs.
Good Luck
Stan
