Tractor Talk Discussion Forum
Stroke control kit
Butcher
03-19-2005 09:07:38
The local farm/fleet has a hyd. stroke control kit on sale. It looks like a set of aluminum doughnuts that clamp on the cyl. ram. any one ever use these? thanks.
Leroy
03-19-2005 18:17:31
 Re: Stroke control kit in reply to Butcher, 03-19-2005 09:07:38
Just be sure you buy the correct diameter for your cylinder piston rod, come in 1", 1 1/8", 1 1/4" possibly other sizes, used then for probably 20 years
kyhayman
03-19-2005 10:21:25
I use them on my batwings center deck to set the cutting height. I can raise the mower to the limit or the cylinder stroke but it drops to the preset level. Also use them to set depth on no till drill. Same principle. They work perfectly to prevent full retraction or to return to a preset length. They dont help on the length of the full extended stroke.
Dan67
03-19-2005 11:32:12
 Re: Stroke control kit in reply to kyhayman, 03-19-2005 10:21:25
We use them in the marine bussiness for setting the stroke of hyd. rams on trim cylinders(there made out of zinc) work good.
Butcher
03-19-2005 09:40:29
third party image
These gizzmos.
Coloken
03-19-2005 09:27:44
If you are thinking what I am thinking, every farmer needs a bucket full ot them. A necsity, decesary, (OH hell, you got to have them) Aluminun not as good as iron though.
Allan in NE
03-19-2005 09:16:01
Bucher,
If it is what I'm thinking it is, your cylinder will have to have the 'shut off' plunger.
They wrap around the cylinder ram and are held together with a thumbscrew tightener? This type works great with IH cylinders, anyway.
But, maybe you are looking at something totally different, tho.
Allan
Butcher
03-19-2005 09:26:54
 Re: Stroke control kit in reply to Allan in NE, 03-19-2005 09:16:01
that sounds like it. I have an 8" cyl. that I would like to shorten to a 6" throw. Its just a generic one from TSC. I guess I am to cheap to buy the cyl. I need.
Allan in NE
03-19-2005 13:45:22
 Re: Stroke control kit in reply to Butcher, 03-19-2005 09:26:54
Butcher,
Just goes to show how far behind the times I am; never seen that type before, but they should work great from the looks of 'em.
Thanks for the picture,
Allan
paul
03-19-2005 10:22:16
Assuming yout tractor has detents, those gismos work well with most any cylinder. The hyd go into bypass & flip the control lever off, as if the cyl had reached max stroke.
They work with the IHC type as well, when the thumbscrew deal strips it's threads & you don't have anything else along in the toolbox.....
Anyhow, started using them (like your picture) 5 years ago, work well.
--->Paul
Harley
03-19-2005 10:23:32
 Re: Stroke control kit in reply to paul, 03-19-2005 10:22:16
Oh man!!!!! !!!! I thought it was something to help do away with stress so I could keep living. Oh well, better luck next time, Harley
