Tractor Talk Discussion Forum
what is the thing on each end of a top link called
Amishbob
03-16-2005 16:08:49
I Am trying to find a top link for my 411 Case and thanks to the information I recieved here I realize I need a top link with the off set to clear the hydraulic housing but it would seem to me that those ends might be available from an industrial supplier and you could utilize the readily available center section to duplicate the case top link by replacing the end assemblies with a set of off set ball socket things like on the original if I knew what those ends were called I'm sure I could find a supplier but Being senile I cant think of what they are??
BBx
03-17-2005 10:17:05
 Re: what is the thing on each end of a top link ca in reply to Amishbob, 03-16-2005 16:08:49
I thought it was called a ball socket just like you said. Open link below.
mike1111
03-17-2005 09:13:46
I think I understand your problem, and I have bought TSC top links and have had to grind some off the end to keep it from binding, mike1111
Joe (Wa)
03-16-2005 20:44:27
Their are called links, the front link is rh thread and the rear link is lh. The center piece is a turnbuckle.
Joe
RP
03-16-2005 18:02:43
We always called 'em "rod ends". I think that's what most suppliers call them too.
Paul in Mich
03-16-2005 17:26:52
Are you talking about Wichamacallits?
Sloroll
03-16-2005 17:59:00
 Re: what is the thing on each end of a top link ca in reply to Paul in Mich, 03-16-2005 17:26:52
Tractor and implement
RP
03-16-2005 17:05:25
Ray
03-16-2005 17:04:24
I bought a top link that would work on a 411 at
a tractor supply store for $20.
Amishbob
03-17-2005 07:29:25
 Re: what is the thing on each end of a top link ca in reply to Ray, 03-16-2005 17:04:24
I bought a cat 1 top link at fleet for 15.00 but it wont work exactly right on all my impliments,without the offset it hits on top of the rear housing and wont drop low enough.
Harley
03-16-2005 20:19:33
We always called them holes.:-0
