Tractor Talk Discussion Forum
farmall 460 hydraulics
newt
03-15-2005 16:29:20
I've recently bought a 460 utility. It has a 17 gpm gear pump which serves a valve bank beneath the steering column. the tractor had teh original steering system stripped when I purchased it so I have no reference for some parts.
there is a small 1/2 inch or so line coming from the pump to the valve bank. I've been told that it might have served the steering system or is a sensor line for the gear pump but I'm not certain. the line goes to a small valve on the side of the gear pump. Which if either of these ideas is right?
I've also been told that it is a closed center system, is this true?
The hydraulics are quick but the loader won't lift heavy objects. On the valve bank there is a spring loaded section with a small screw which can be turned in or out, does this regulate pressure?
geok
03-15-2005 18:12:07
 Re: farmall 460 hydraulics in reply to newt, 03-15-2005 16:29:20
the system is an open not a close. As for the loader. Check pressure coming out of control valve. Normal pressure is 1350 psi. If the pressure in normal, the cylinders on the loader may not be a large enough bore to lift the loads you are wanting to lift.
