Tractor Talk Discussion Forum
41 A John Deere , water in oil
William Wallis
03-15-2005 15:37:10
I just bought this old long hood and when I drained the oil from both the crankcase and transmission I found gray/light brown oil.The oil was full to the overflow.It did have a slick feel between my fingers but the color told me there was condensation. I don't know how long it has been in the tractor but I assume a couple years.My question is what should I do? Tear it down? Wash it out ?
DRL
03-15-2005 18:42:55
 Re: 41 A John Deere , water in oil in reply to William Wallis, 03-15-2005 15:37:10
Suspect that it is condensation or rain water. Lots of places for the water to get in if left outside. Follow the advice you have already been given and all should be good. Give it a good workout and get her good and hot. That should remove any remaining moisture.
old
03-15-2005 17:20:25
I've run in to that a lot, all I ever do is drain the oil after running it for a few minutes to get the engine warm. Then I leave the plug out of it for an hour or so, then fill it back up with oil. Then I run it as normal and change then oil in a week or so. I've never had any problem when I have done this.
PeteNY
03-15-2005 15:50:40
WW, We drain, then partially fill with kero, the turn it over a few times, then pull it around the yard a few times to let the kero slosh around, drain,then fill it with cheap oil, run it a while, drain again, then fill with good oil. Change the folter each time! Pete
