Tractor Talk Discussion Forum
ethanol use...
Tim Shultz
03-14-2005 06:42:18
I would like to know why we can't use ethanol in tractors/cars/trucks? seems it would save a lot of people a lot of money. and it would help out the farmers a bunch! what do you guy's think?
Tim
NEsota
03-14-2005 21:43:09
 Re: ethanol use... in reply to Tim Shultz, 03-14-2005 06:42:18
Gotta check the coordinates. Don't know if Minnesota is in the Mid-west or Middle East. Sooorry, couldn't resist.
David B
03-14-2005 15:08:50
To run on pure ethanol or E85, you just have to modify your fuel system some, some new cars come factory ready for E85.
The only other problem with ethanol is ethanol is also a detergent, so it cleans the crud out of your gas tank. After a while on ethanol, change your fuel filter.
Do you ever hear about guys running on alcohol having problems? Nope. Do you know that ethanol is alcohol (ethyl alcohol)? The biggest disadvantage to ethanol is the lack of knowledge about it. There are too many bad rumors about ethanol floating around that are not factual. I've read a few of them on this post even. Do some researth for yourself, ethanol is good stuff!
George in B.
03-14-2005 11:11:00
Gas does not even smell like gas anymore. Has'nt in a long time. There has to be more than 10% of somethin in there. I love how everyone says that the supply is low and that is why the price on fuel is high. Then, the oil companies post record profits.
buickanddeere
03-14-2005 10:39:41
Ethanol is used mostly at 10% as previously stated to cut emissions,not corrode fuel systems and not rquire re-jetting. Ethanol is distilled from the grain mash and that heat energy has to come from $$$ somewhere. Plus the cost of grain, equipment and transportation. Unless you are using steam from a nuclear reactor during off peak at nights and on weekends. The cost of boiling off the ethanol with natural gas, LP or petro fuel oils will neevr pay. The only way ethanol is limping along at all is tax incentives. And making fuel companies look good along with the polititions in the media. The oils squeezed from grains have a much lower energy input cost. Feed value is still better than brewers grain afterwards too.
Gerald J.
03-14-2005 14:46:45
 Re: ethanol use... in reply to buickanddeere, 03-14-2005 10:39:41
You neglect the side products of heat suitable for green houses and the feed of the dried distiller's grain. Both are easily destroyed side products. The feed has high food value for cattle and pigs.
You demand distillation by heat alone, when a combination of less heat plus vacuum and other chemical water removal techniques may be applied.
Try the links I've mentioned below to see what the profits really are.
Gerald J.
paul
03-14-2005 12:04:37
I disagree with you. Ethanol in 2005 produces more enery than it uses, including growing & transporting the grain. Your data must be over 5 years old, or straight from Big Oil - where they tried to include the energy coming from the sun as a negative input, along with others.
For a ture playing field, let's cut every govr subsidy to petrolium companies, and every tax incentive to ethanol plants. See who comes out with a cheaper fuel.
I'm game.
The current tax incentives are needed to build & mature a new industry. Govt does that all the time - railroads, autos, iron production, petrolium too all had their share of govt subsidies to get the industry started.
--->Paul
RustyFarmall
03-14-2005 11:12:23
True, it does cost something to produce ethanol,but gasoline doesn't just mysteriously appear either. If ethanol were to be produced in the same quantities as gasoline the price per gallon would be even cheaper than gasoline, and we would no longer need the tax incentive.
buickanddeere
03-14-2005 14:00:53
 Re: ethanol use... in reply to RustyFarmall, 03-14-2005 11:12:23
Coal would have to be used to distill the ethanol that cheap. The price of grains would skyrocket and other sectors of the economy would now be upset. I like the idea of burning somebody elses oil and leaving our oil alone in reserve. Then there is several hundred years worth of synthetic oil and fuel in those coal fields too.
Mark - IN.
03-14-2005 16:57:20
 Re: ethanol use... in reply to buickanddeere, 03-14-2005 14:00:53
Hey ya Buick. Funny that you should mention coal. My job takes me into coal fired power plants a lot, and I've picked up a thing or two. I always thought coal was coal. Nope, all kinds of hybrid mixtures, and the stuff these guys use takes off on it's own at low temperatures. One of the types the feds requires them to burn in the next couple of years is a low sulpher that can only be found in two places, somewhere in Utah that was earmarked as "National Parks" and can't be touched (the last President did that, not the current one), and somewhere in the middle-east, falling under the control of the Ligget Group (may have mispelled their name), whom were heavy donaters to his political party. Aint that something? Is true.
Mark
buickanddeere
03-14-2005 17:50:40
 Re: ethanol use... in reply to Mark - IN., 03-14-2005 16:57:20
They burn that stuff here at Nanticoke and Lampton as well. It does burn much cleaner but has fewer BTU's per ton. During peak demand about 30% hard Anthracite gets blended in to get the units up to max MW's. As for spontanious combustion. Yes that stuff is like linseed oil soaked rags left in a pile. The entire coal yard is sprayed down with water and the coal stirred around. Shallow strip mining in the west is way cheaper than deep shaft mining in the east.
Mark - IN.
03-14-2005 18:15:50
 Re: ethanol use... in reply to buickanddeere, 03-14-2005 17:50:40
I caught a show on RFD dealing with a big grain outfit/setup I believe in one of the Dakotas. I'm watching them bringing grain from a conveyor across the top of the biggest quanset hut I've ever seen for storage, and they've got a tripper moving back and forth dispersing it, and some of it's being pushed around in piles forcing it to drop down to a converyor below ground where it's going up several small conveyors to semis for distribution. As I'm watching this, I'm thinking I see this all the time, just backwards, on a much larger scale, and not nearly as clean.
By the way, I'm a phone repairman and don't mind going down into the tunnels or up on the stacks. And as long as the other guys don't like getting dirty and are afraid of heights, well keeps me working. No complaints, work is work and pays my bills.
Mark
TGIN
03-14-2005 09:35:18
The Indy 500 cars are to be running on 100% ethanol in the year 2007 , they all will run 10% next yr. That will be a big boost to the program .
dej(JED)
03-14-2005 09:30:15
100% Ethanol is currently in use in S.A., as is 85% ethanol fuels. The biggest changes seem to be the gasket materials. Viscosity is the only issue that a fuel system must address and ethanol is similar to gasoline in that regard, so pumping and injecting is not a problem. However, the BTU value of Ethanol is lower than gasoline and therefore it won't perform as well as gasoline.This means less miles per gallon. RFG(Reformulated Gasoline)has been in use in the USA for a while now and it is a 10% blend of non petroleum products with a petroleum based gasoline. Engines, especially the old tractor engines love the extra oxygen bonds that they get from alcohols, etc. The bigest problem with ethanol is it's propensity for water, so care to keep it dry would be the major concern. As I understand it there are stations in the Midwest that sell it at the pump..
Midwest redneck
03-14-2005 08:38:30
A friend of mine who is an engine engineer at Ford says that Ethanol has half the energy of gasoline. So if ethanol is half the cost of gasoline then you would break even. I think I had heard that Gasoline has to get to $2.50/gallon until you see an advantage from ethanol. I am not sure if this is right.
paul
03-14-2005 11:58:49
 Re: ethanol use... in reply to Midwest redneck, 03-14-2005 08:38:30
Man, there is a lot of bad info out there.
Ethanol has about 1/4 less btu per gallon, but it has somewhat better burn characteristics, so you lose perhaps 1/6 mpg on ethanol. That is a far cry from 1/2 as your friend claims.
His numbers would be right for methanol, but that is not the product being used these days.
There is a world of difference beween mthanol & ethanol, seems Big Oil has done a good job confusing people. Funny thing is, they are the one's who produce methanol & pollutied west cost groundwater with that stuff!
The Indy racing series had burned methanol for decades, but are switching to 10% ethanol this year, & 100% ethanol next year.
--->Paul
RustyFarmall
03-14-2005 12:50:14
 Re: ethanol use... in reply to paul, 03-14-2005 11:58:49
Paul, I agree, there is a wealth of misinformation available on the net. The funny part is that people will come to this sight, ask questions about their old tractors, and believe what we tell them because they can take that information and get the old tractor running. The same people will then ask questions about using ethanol and, with the exception of a few, will not believe anything we tell them. We are the ones who have been using the ethanol, we are the ones who can buy it at the pump, and we are the same ones who would not use it if it did not perform equal to gasoline. It just gets to be quite frustrating at times.
dr.sportster
03-14-2005 09:45:30
It has less btu than gasoline but it has a higher vaporization rate.It makes more power because you can feed more to the engine.It is true that for a methanol carb starting jet sizes would be about double[or more] in size of a gas carb.Dont know too much about ethanol but I know we better come up with an alternative fuel pretty soon.Switching from gas to methanol yeilds 15 to 20% HP increase.A slower flame speed of methanol requires more ign. advance.The good thing is you can cheat in a little nitromethane to alcohol fuels adding nitro to gas will slow you down and stink you out.All this has little to add to the original discussion.Oh well.
Jonboy
03-14-2005 08:27:10
Intersting reading here so far. Here in Vermont I don't see any bio diesel or ethanol blends, just regular ol' petrolum fuels is all thats avalible as far as I know, and I have yet to see a gas station with a bio fuel pump. I wonder if it's because all of the corn produced around here is destined for dairy cattle feed and there isn't any soybean fields around?. Plus with the winters here, the bio fuels freeze easier than petrolum fuels and thats why I don't see them here.
Mike (WA)
03-14-2005 08:15:22
Diesels present another problem. Ethanol, like gasoline, cannot be used in any significant concentration in a combustion-ignition engine. Much research going on with the various vegetable/ plant oils for replacing diesel. And with diesel at $2.75 a gallon and rising in western Washington, I sure hope they are moving right along on their research.
RustyFarmall
03-14-2005 07:48:31
I have been using the 10% blend ever since it became available back in the 70s. I use it in everything I own, from the 1940 tractors, up to the 2002 Chevy Trailblazer and everything in between which includes garden tillers, lawnmowers, chainsaws, even used it in the two stroke dirt bikes.
Mike(inWisc.)
03-14-2005 07:28:08
Well, We CAN use ethanol in trucks and tractors, and we ARE.
However, it is generally not advisable to use more than a 10% mixture with gas without some modifications to the fuel delivery system. High concentrations of ethanol will cause corrosion problems, and do require some sort of atomization adjustments to the carb. I do not know much more about it.
I do hear that there are places in Minnesota that are offering gas with up to 85% ethanol. Claim that it works without problem, but I have yet to confirm that.
I think that ethanol is just one of about a half dozen things that could be further developed to reduce our dependance on foreign oil.
Mike
RustyFarmall
03-14-2005 07:37:10
 Re: ethanol use... in reply to Mike(inWisc.), 03-14-2005 07:28:08
I have never heard of ethanol causing corrosion. Methanol WILL cause corrosion, and to the best of my knowledge, methanol is no longer being produced as a motor fuel.
Mike(inWisc.)
03-14-2005 10:31:44
 Re: ethanol use... in reply to RustyFarmall, 03-14-2005 07:37:10
Well, I am no expert and you could be right, but here is what I heard about it.
Ethanol in pure form is corrosive, and cannot be transported in a pipeline for that reason. When we had that price spike around the Chicago area back in 2000. They claimed it was because they could not reformulate the new gas here in the midwest, but had to do the blending at the refinery.
Like I said, don't know if it is true, but my understanding is that blended ethanol is ok, but pure stuff is corrosive.
Greywolf
03-14-2005 16:09:59
 Re: ethanol use... in reply to Mike(inWisc.), 03-14-2005 10:31:44
Ever have a drink of Everclear????? ??? Same thing as 100% ethanol...ok ok ok.. 95%.
RustyFarmall
03-14-2005 13:56:40
Mike, do yourself a favor, get a bottle of rubbing alcohol, (basically the same thing), and then find a piece of bare cast iron, pour the alcohol on the cast iron, and see what happens.
Mike (WA)
03-15-2005 08:48:41
 Re: ethanol use... in reply to RustyFarmall, 03-14-2005 13:56:40
I think rubbing alcohol is either methyl or isopropyl alcohol- not the same thing.
paul
03-14-2005 11:52:13
That is about the most off the wall thing I ever heard, straight from the Big Oil Corporation I'm sure.
Not true.
You are confusing Methanol (wood alcohol mad from petrolium) with ethanol (made from grain starch).
--->Paul
Mike (WA)
03-14-2005 08:12:22
I recall from the fuel crisis of the 70's (remember, when gas zoomed up from $.30 to over $.70?) that methanol worked better so far as combustion was concerned, but soon was dropped because of the corrosion problem.
Gerald J.
03-14-2005 07:25:30
Straight ethanol (200 proof) is drinkable. So it has to be made deadly or the taxes are unreasonable. Adding gasoline is one of the accepted ways of making it not drinkable.
All of the gasoline sold in some areas like St. Louis has 10% ethanol. Reduces pollution. In some states, like Iowa, the road tax on ethanol is lower so that 10% ethanol blends cost less and so sell well.
In Missouri and Iowa and other states, many state owned vehicles run on 85% ethanol, E85. These are available from the major makers as Flexible Fuel Vehicles. At least in the Ford Taurus, the FFV option is a no cost option. There seems to be a few hundred thousand FFV on the roads in the US now.
In some states, e85 is hard to find, though there are many pumps for it in Minnesota and Iowa and Northern Missouri.
I spent part of last evening researching the conversion issue. For a fuel injected engine it seems to boil down to replacing the injectors with injectors having 30% greater maximum volume and adding better flash back protection at the gas tank filler. That's to make a vehicle run on E85. For a carburetor engine it gets more complex. First there's generally no computer to monitor the oxygen in the exhaust and adjust the mixture for various fuels, and ethanol hasn't the multitude of low temperature vaporizable fractions (its all the same chemical compound) for low temperature starting. E85 helps the low temperature starting by having 15% gasoline, but some reports indicate that it may take adding a separate gasoline fuel system for cold weather starts. The fuel pressure of fuel injected systems gets ethanol vaporized at low temperature, but even then some hint it helps to warm the fuel before a cold start.
My gas 4020 runs rough on E10. That may be because it has a cold intake manifold that tends to run the end cylinders more on condensed liquid. It has provisions for heat and the manual calls for heat running gasoline on light loads up to 90F but there's a big crack in the heat part and I don't want to listen to raw exhaust out that crack. I may need to fix that with another manifold. Some of the literature says that good manifold heat is necessary for running high percentages of ethanol fuel.
EPA and CARB are opposed to after market conversions afraid that they will cause excess pollution and so require massive tests that can't be achieved by a company smaller than Ford or GMC and both of those prefer to sell a new vehicle than update an old vehicle.
There are at least 4 E85 pumps in my county, possibly 5 right now. And there are probably 100 E10 pumps. At least one third of the gas pumps around here pump E10.
So WE DO burn ethanol. We could burn more.
Gerald J.
MN_FISH
03-14-2005 08:14:01
 Re: ethanol use... in reply to Gerald J., 03-14-2005 07:25:30
We use ethanol in everything that burns gas. I"ve used it since it was available in MN. To use 85% your owners manual of the vehicle will tell you if your vehicle can use it. On older vehicles you might have to change gas filters being the ethanol cleans the tanks and if there was any rust or crud in the tank it will plug the filters. After a couple of filter changes there is no problem. Newer vehicles there"s no problem. With the ethanol your gas system won"t freeze up. No need for adding any deicers to the gas tank! They are working on soy diesel now for diesel engines. I think the blend now is 10% or 20% soy oil and the rest diesel. There are some diesels now they are burning 100% soy oil. The more of these fuels we use we are less dependent on foreign oil.
Tim Shultz
03-14-2005 08:27:53
 Re: ethanol use... in reply to MN_FISH, 03-14-2005 08:14:01
thanks for the info, but could you guys tell me more about changing an older tractor or truck to ethanol? how much would it cost? where could I get the fuel? northern IN. how hard would it bee to change over? thanks!
Mark - IN.
03-14-2005 16:37:41
 Re: ethanol use... in reply to Tim Shultz, 03-14-2005 08:27:53
Tim, you say "converting" over to enthanol. I'm not quite sure what you mean by "converting". Are you asking will it affect your old lead lubricated valves in the same way unleaded gas does? I'm sure it does. It does dry stuff our (gaskets, diaphrams, etc) as priviously posted. It does help evaporate water, so less need for Heat, or the equivelent. It also cleans the insides of carbs up too, which was a big complaint when it had a tendency to "gum" stuff up by cleaning years of varnish and crap out. But as priviously stated, change a filter or two, and will work fine. And if you're buying gasoline in northern Indiana, chances are excellent that it already has enthanol in it (check the pump).
As for where to buy it directly, not sure. Was an ethanol plant in Goshen on Pike St, was a farm coop that was booming in the 70's. Think the plant's still there - not sure. There's a massive plant somewhere west of Southbend, can see it from the Interstate. Will they sell to you directly? Don't know. I'm assuming that you're not going to try to run that stuff straight in your engines, so why not get it premixed from the supplier? After 911, if you go walking up to a plant asking questions, innocent ones at that, might have to answer a few too.
Mark
Mark - IN.
03-14-2005 16:36:45
Mark
paul
03-14-2005 11:45:48
Minnesota must be way, way ahead of the curve on this issue..... All pumps are E10, so it is easy to get, and E10 will work fine in the tractor as is.
I went to a one day seminar on producing your own & converting gas tractors back in the 80's. In our cold temps, you need to start them on gasoline, get a little heat into it in winter, then switch to ethanol in winter. In summer no big deal. They were producing E95 perhaps on the farm in a big LP tank - the other 5% was water.
You build a small water jacket plate for the carb to mount on and use coolant to heat the carb area, or a simple tin shroud over the muffler and connect the air intake to this. Got your heat for winter use.
The ports need to be opened a bit, and some plastic/rubber parts may need to be swapped to different plastic/rubber parts. As mentioned, fuel filters will plug on old machines as the ethanol loosens all the crude in your tank.
That's about it.
E85 can be had at one in 5 fuel pumps here in rural Minnesota, shouldn't have to travel more than 20 miles to find it. Get your state government on the ball to get up to speed on this.
Minnesota is about to kick in the bio-diesel now, starting with 2% soybean oil in all diesel fuel sold. That will ramp up to 5% over the next couple of years.
Legislation is in the govt this week to boost the mandated E10 to be E20 for gasoline starting next year. Not sure if it will pass, but would require all road gasoline to be 20% ethanol.
Those states that lage behind are going to be left out on the energy front. We have windmills popping up all over the sw corner of the state as well.
All of these projects are long-term investments, cost a lot up front, look like they won't pay off - but then bam, price of gasoline goes up 60%, and suddenly it looks pretty good. We have some of the cheapest electricity in the nation from coal-fired plants; yet the stae mandates some re-investment into wind & other bio-electric plants just to get the ball rolling.
Many other states, oddly California among them, are opposed to such things. I think those states might find themselves on the outside looking in. There are ethanal plants, owned by farmers, all over the state of Minnesota. Couple of soybean crushing plants are being built, more being thought about.
Where will your state's crops be used, where will your fuel come from in the future? Where will the jobs be located?
--->Paul
ChrisH(IA)
03-14-2005 11:37:35
Ethanol blend will dissolve the shellac that binds the cork together in carburetor gaskets and floats. My 68 ford sits out in the barn from november till march and the Holley always needed new gaskets cause as the fuel evaporated, the gaskets shrank. I started putting in the pricey premium gas about 5 years ago and haven't had any more problems. One other thing-the blended fuel will separate with the alcohol on the bottom of the tank or gas can--that's generally why "old" gas won't fire in the lawn mower in the spring even though it ran fine when put away. Any corrosion that occurs is cause the alcohol absorbed water in the vented tank and forms a weak acid that slowly eats thru any pin holes in the zinc tank liner. Chris H (IOWA)
RustyFarmall
03-14-2005 12:57:13
 Re: ethanol use... in reply to ChrisH(IA), 03-14-2005 11:37:35
I have a '71 Ford that sits outside all the time, never had a problem with the holley on it.
JT
03-14-2005 11:31:51
I unlike Rusty, do not recommend putting it in chain saws, lawn mowers, or any other thing running rubber parts in the fuel system. I have a terrible time with rubber diaphrams getting hard and also rubber fuel line disolving with ethanol fuel. But untill I went to diesel in my truck I always run 10-15% gasahol and had great luck with it, still use it in wife's van. I have used it in my old tractors with no adverse affect, just make sure tanks are clean before you put it in, because it will clean the tanks and system quite well. As for straight alchohal in older trucks and tractors, read, read, read, it will take bit of modification to make it work.
RustyFarmall
03-14-2005 13:05:53
 Re: ethanol use... in reply to JT, 03-14-2005 11:31:51
Stihl chainsaw sat for two years with about a half tank of fuel. Dumped out the old fuel, put in fresh and it started and ran on the third pull. Likewise with the lawnmowers and garden tiller. I never drain the gas at the end of the season. Whatever is in the tank when I shut it off is what's in it when I prep it for use the next spring. I have been doing this for more years than I can remember, I have never had a fuel or carb related problem. I do not use Sta-bil either.
Gerald J
03-14-2005 10:30:28
Today a google search on E85 turns up on 515,000 hits. The first one is linked below.
As I said above, converting an injected engine appears to be far simpler than converting a carbureted engine for 85% ethanol.
Using E10 (gasohol) in a vintage engine may mean no more than making sure the ethanol doesn't dissolve fuel lines, float varnish, gaskets and o-rings. There is chance that the ethanol content may loosen crud in tanks and lines, but modern gasolines often have detergents that should have already cleaned the lines. If gasohol does loosen crud the fuel filter will catch most of it.
Running E85 through a carburetor is more difficult. Takes effective manifold heat, larger jets (27% in diameter according to some research reports I found on the internet yesterday), and provisions for some other fuel or warming the E85 for cold starts. Also those documented projects I've found mention working at better fuel tank filler fire flashback prevention.
EPA and CARB are against E85 conversions not done by factories and require a regimen of tests impractical for individuals.
Gerald J.
RustyFarmall
03-14-2005 10:06:13
The 10% ethanol should already be available in northern Indiana. The pump may not be labled "ethanol" but the ethanol blend will have a higher octane rating than your basic unleaded, something like 87, versus 85? You do not need to make any changes to any of your engines, just pour it in the tank and go. The ethanol will have a tendency to "clean" the fuel system, so you may want to buy some extra fuel filters to fit the vehicles you have. You shouldn't need to change the filters more than a couple of a times, and then everything will be just fine.
JMS/MN
03-14-2005 12:56:49
 Re: ethanol use... in reply to RustyFarmall, 03-14-2005 10:06:13
Paul has done an excellent in refuting all the bogus claims of the naysayers, and showing how our state is way ahead of the Nation in alternative fuels. Your claim about plugging filters is appropriate for METHANOL- not ethanol. Had the same problem many years ago when some stations sold it in gas, while others bad-mouthed it. Never had the problem with our 10 percent mix of ethanol in our gas. MTBE, the crap that oil companies made, and was found to pollute ground water, is on the way out. And the arguements about it taking more energy to produce ethanol than what it produces are just hogwash. By the way, what is the real cost of oil from the Mideast, even without putting a price on American lives- ie- US Military expenses to ensure delivery?
riverbend
03-14-2005 15:21:55
 Re: ethanol use... in reply to JMS/MN, 03-14-2005 12:56:49
It would be good to get some information without all the spin and bs from either side. I have heard numbers from $5-$9 per gallon for gas, depending on what they include for securing oil from the mideast. I have also heard that ethanol takes 10% more or 10% less energy to produce than it contains. It seems like everybody is pushing their own agenda and nobody plays it straight.
paul
03-14-2005 16:56:14
 Re: ethanol use... in reply to riverbend, 03-14-2005 15:21:55
I do understand that. :)
Five years ago, they were getting 2.5 plus gallons of ethanol from a bushel of corn. I don"t know how much energy they used to distill it. And I don"t know the energy used to grow corn exactly.
Now in 2005, they get 2.7- 2.9 gallons of ethanol from a bushel of corn. They have refined their process & use less energy now per gallon than they did 5 years ago. As well, there is more notill corn, and yields have gone up, so it takes less fuel to make a bu of corn today than it did 5 years ago.
Put all together, any data from 2-3 years ago is already outdated. What I read these days is about the 1.6 btu produced for every 1 btu used in the manufature of corn. This is accounting for the feed produced, and the bubbly air made as well. Since they are sold, they have value, & should be accounted for somehow. Like you say, there seem to be several different ways of proving one"s point. :)
Five years from now, the equasion will be even better.
I don"t believe ethanol will ever replace our petrolium needs.
But, it can help. Just the anti-pollution effects of a 10% blend of it are worth looking at. I"m not sure it would be practical to convert all our cars to E85 machines & try to produce that much. But perhaps getting 10-15% of all road fuels to be ethanol would be about right? That amount would help air quality, would let us get more out of the crude we use (ethanol raises octane, allowing it to be mixed with lower grade gasoline....) and heck, decreasing our gasoline consumption by 10% would have to help with international affairs & production & enviornmental drilling issues....
Biodiesel is a little more exciting. I believe it takes less energy to produce, and packs more energy in a gallon. Oil seeds use no N fertlizer, so we don"t put as much petrolium into it"s production.
There is ethanol in straw & corn stalks as well, just very costly to try to pull it out. It will be interesting if a use for this biomass ever comes about.
Will be interesting.
If Minnesota can make the ethanol & biodiesel blends work out, everone else should. Winter is a tough time up here. :)
My fuel coop has discussed biodiesel several times. It will jell in winter moreso. Many farmers are ordering a barrel of bio & blending their own, using it already up to 5%. It is working, and it is available now. It offers some lubricating qualities that the low sulfur standards are removing, so might end up being a good mix.
Regurdless, petro-based liquid fuels will be our staple for mny years to come, I"m not figuring there will be any mad rush to a different fuel. Just pecking away at it, a few % here & there.
--->Paul
cdmn
03-16-2005 17:11:41
 Re: ethanol use... in reply to paul, 03-14-2005 16:56:14
If you can get more miles per dollar with ethanol than you can with diesel, then it's cheaper. However, you have to consider the subsidies involved when you compare costs, that includes to-the-farmer subsidies as well as to the distillery subsidy. Sure there's a military cost involved in importing fuel, but it's spread out over everything. If it was paid for by an excise tax on fuel, then there'd be some griping! It could be that growing firewood is more energy efficient than growing and processing corn. Once upon a time we were self-sufficient energy producers, it was called "woodlot", "pasture" and "horse hay".
I will feel more convinced when the distilleries start to use their own fuel to fire their boilers and when the farmers take gasohol instead of cash for their corn and when the employees at the distillery all use gasohol vehicles. In the end, the price of anything reflects the energy content. The only way to slow energy consumption is to slow down the earning and spending power of the society. That means earlier retirements, more time in college, more stay-at-home spouses, more manual labor, more unemployment, and a reduction in population levels. etc. If people got cheaper fuel, they'd use the money they save to buy something else, or have another baby or something. Anyway, that's some of my arguments.
Old Time Farmer
03-14-2005 14:17:31
As another Minnesotan, I was going to post on this, until I saw Paul had done it way better than I could.
