Tractor Talk Discussion Forum
cub cadet /k241A carb problem
scott tague
03-09-2005 07:49:42
Just a novice; tractor will start when I prime carb w/fuel on a rag, but then stops. I added new fuel to tank, tractor has sat for several months.
Fuel is flowing from gravity feed on tank. The bowl below the carb is dry. Should it be full of fuel? What can I do to get it running?
Dr.EVIL
03-09-2005 09:18:10
 Re: cub cadet /k241A carb problem in reply to scott tague, 03-09-2005 07:49:42
Sounds like the main fuel jet is stuck closed from sitting with gas in it. Light tap with something light, like a scerewdriver handle "MAY" jar it loose. Carb body is diecast and is not repairable, and replacement carbs are over $150. Be gentile.
sammy the RED
03-09-2005 08:16:38
Take the carb apart and rebuild it.
Kits are only a few dollars.
