Tractor Talk Discussion Forum
John Deer B Block Repair
Harold R.
03-08-2005 19:08:00
I have three small holes rusted through the waterjacket of a 1939 B block. How can I repair it? Welders say they can"t weld it. Should I try JB Weld or does anyone have a better suggestion?
Thanks!
Earl S.
03-09-2005 18:55:07
 Re: John Deer B Block Repair in reply to Harold R., 03-08-2005 19:08:00
Harold,Exterior btm of block????Is there enough metal left in the wall to drill and tap for cast pipe plugs??Earl
Harold R
03-10-2005 17:35:15
 Re: John Deer B Block Repair in reply to Earl S., 03-09-2005 18:55:07
Earl S. Thanks for the info. You are the second person to recommend this. The holes are on the exterior bottom of the block. I am going to try a new product called Magnum Steel. It's a putty with hardener that is supposed to be as hard as steel. A small package was $5. A John Deere dealer recommended it. The package claims that I can drill, tap or machine it in one hour. What do you think? Harold R
the tractor vet
03-09-2005 17:38:15
I did a J D B many years ago for a guy he forgot todrain it and it broke a big pice out of the bottom of the block we found most of the pices and like a jigsaw puzzel we fitted them all back that we could find i pre heated the block with a rose bud tip cleaned the pices up wit a grinder and started tacken them in then went in with the grinder and Vee them out and started stich welding them in with Ni cast and peened after i would weld about and inch and a half kept it up till i had to do the bridge work and filled in with weld kept the heat on for a while then started backing the heat down , now to my knolage that when the old man died and the old Deere sold at his sale it was still running and not leaking.
buickanddeere
03-08-2005 21:01:32
Are the pits in the bore were the walls can be sleeved?
Harold R
03-09-2005 13:24:03
 Re: John Deer B Block Repair in reply to buickanddeere, 03-08-2005 21:01:32
The holes are on the bottom of the block through the water jacket. They are about the size of a thumbnail (after we broke it out to get to solid metal).
george md
03-08-2005 20:45:05
Harold,
Take some pictures of the holes and put
them in the email so I can look at the problem.
I do some cast iron repair. Link below to my
web site and the email is in there .
george
Harold R.
03-09-2005 13:34:38
 Re: John Deer B Block Repair in reply to george md, 03-08-2005 20:45:05
I sent the pictures to you George. Let me know what you think.
george md
03-09-2005 23:25:47
 Re: John Deer B Block Repair in reply to Harold R., 03-09-2005 13:34:38
Harold, email is on the way.
george
Harold R.
03-10-2005 17:36:29
 Re: John Deer B Block Repair in reply to george md, 03-09-2005 23:25:47
Thanks I got it. Good advice. Harold
