Tractor Talk Discussion Forum
OT rebar vs post tension
Jerry C
03-07-2005 06:15:22
Getting ready to have a house built in NE OKLA, would like some input on rebar vs post tension concrete slab. price of steel has made either choice priced about the same Thanks in advance Jerry Castleberry
sjh
03-07-2005 19:48:00
 Re: OT rebar vs post tension in reply to Jerry C, 03-07-2005 06:15:22
Jerry
Can you give more info. The reason for post tensioning a slab is to give it camber so when it is loaded the slab does not deflect( negitivly bow). If this is a on grade slab I see no need to put strand(the cable) in it. Just use the right amount of rabar.
ChrisH(IA)
03-07-2005 13:37:31
The post tension slabs I've worked on were for commercial buildings that were open under the slabs--fewer support columns-more open area. Even those had a lot of re-rod in them, so I'm not sure how it can be "versus". Is the slab poured in place, as a high rise building would be? If it isn't open underneath, I see no point in the added expense (cables)and labor (post tension hydraulics) necessary to do this. ChrisH(IA) (formerly from El Reno)
