Tractor Talk Discussion Forum
Log splitters
Forrest10
03-06-2005 21:48:35
I recently bought a log splitter for about $200,
and also just finished rebuilding the carb.
Now that i got it running,tried to split some wood. The engine shuts off when i operate the lever for the hydraulic. Does anyone know why or what would cause this. please fell free to email me. Thanks
Kevin (FL)
03-07-2005 07:41:37
 Re: Log splitters in reply to Forrest10, 03-06-2005 21:48:35
Make sure you're not pushing the valve handle "halfway" or partially. If you do this the valve position can cause a "deadhead" on the hydraulics and stall the engine. Other possibilities--a clogged return filter, a stuck cylinder (not likely). The fuel mixture setting as mentioned by Uncle Tom is also a possible cause. Our log splitter will sputter a little if the fuel mixture isn't set "just right". Last thing to check--disconnect the fuel line at the carb and make sure you have good flow into a jar or something. Our tank had lots of trash in it since it sat outside for years before we got it--had to clean the tank and the fuel valve/bowl assembly. We also installed an inline filter in the line between the tank and the carb.
UncleTom
03-07-2005 02:56:33
Try opening up(screwing out) the main jet needle alittle bit 1/8 turn at a time till it will work under load. Sounds like it is lean to me.
country girl
09-11-2005 11:29:16
 Re: Log splitters in reply to UncleTom, 03-07-2005 02:56:33
Can anyone out there tell me why my hydrolic splitter spews forth hyd. fluid from the little hole in the cap/nut of the fluid tank/container/receptacle? Any help appreciated.
