Tractor Talk Discussion Forum
John Deere 750 wheel base width
Thomas Trees
03-03-2005 00:56:05
Some time ago I saw a post reguarding the widening of the rear wheel base of a John deere 750. The tractor is quite narrow and tippy. Is there a way to widen the rear wheel base?
Mike M
03-03-2005 07:11:19
 Re: John Deere 750 wheel base width in reply to Thomas Trees, 03-03-2005 00:56:05
Some of the Farmall Cub's used to have a spacer installed to widen them. I would imagine you could custom make some sort of spacer to go between the hub and the wheel.
Fawteen
03-03-2005 03:36:15
Yes, and no.
The only thing you can do is put the rear tires/wheels on with the dish out. Mine came that way from the dealer. It doesn't make that much of a difference.
On the other hand, the only time I've ever seen (or felt) daylight under a tire is traversing rough ground with a big load in the bucket. Solution: DON'T DO THAT! ":^)
