Tractor Talk Discussion Forum
HELP!! REAR SPOKED WHEEL ON 1938 JOHN DEERE A
howard38
02-28-2005 17:40:33
I AM IN DESPERATE NEED OF A FACTORY FLAT SPOKE WHEEL FOR A 12 SPLINE AXEL ON MY 1938 UNSTYLED A. WHEN I WENT TO TAKE THE COLLAR OFF I FOUND THE HUB BROKEN IN THREE PLACES AND IM SURE IT CAN"T BE WELDED RIGHT THE WAY IT IS BROKEN. I THINK WHEN AND IF I CAN GET THE COLLAR OFF THE HUB WILL FALL APART BECAUSE THE CRACK STARTS AROUND THE SPLINES AND WORK THERE WAY OUT. ANY HELP WILL BE GREATLY APPRECIATED!!!!! ! THANK YOU.
Maark
03-01-2005 08:51:15
 Re: HELP!! REAR SPOKED WHEEL ON 1938 JOHN DEERE A in reply to howard38, 02-28-2005 17:40:33
If that tractor is just for parades, I'd just clean up the axle, maybe squeeze some JB Weld on the broken pieces,remove the excess that squeezes out, paint the wheel and reinstall the collar. Bolt it down real tight and not worry about it too much. I know it won't hold up as good as original but it should be allright for parades and display. No one will probably notice it if you don't tell. It was probably that way when you got it.
