Tractor Talk Discussion Forum
Piston Help!!
danielFarmer
02-26-2005 17:50:51
I am really mad at my self b/c i left my john deere b power block piston on the shelf and came out this morning at it was lying on the floor with a piece broken off it!! It is righ below the last compression ring. It has a slot cut into booth sides of the piston and the lip of the top is what broke off. I guess it hit it at a weak spot or something. Is there any way to fix this!!!!! !
Leroy
02-27-2005 08:05:34
 Re: Piston Help!! in reply to danielFarmer, 02-26-2005 17:50:51
Profesional aluminm welder, not amature, and his were cast iron not your aluminm
the preacher
02-26-2005 20:52:38
try ebay. i saw one on there the other day.
Nebraska Cowman
02-26-2005 18:27:23
Probably could weld it back. I broke a chunk of of an F30 piston and welded it back.
danielfarmer
02-26-2005 18:52:50
 Re: Piston Help!! in reply to Nebraska Cowman, 02-26-2005 18:27:23
what knd of welding and preperation
J.Schwiebert
02-27-2005 08:55:22
 Re: Piston Help!! in reply to danielfarmer, 02-26-2005 18:52:50
Is this a forged or cast aluminum piston? Is the ring groove in tact? Depending on how large a piece broke out you might be better off matching the weights of the two pistons. I also know some pullers who do not run that lower ring.
