Tractor Talk Discussion Forum
Monarch snowplow hydraulic pump on tractor
Dan of Minnesot
02-26-2005 07:20:27
Hello
Sorry for a non-tractor question, but the snowplow is on my tractor and the snowplow is run off a older monarch dyna might hydraulic pump. I hope some one can help me?
Here are the symptoms: The pump is activated by rods or cables. The plow has can be moved left and right as well as up and down. THe hydraulics work the right and left of the blade, but it does not lift the blade. The pump seems to be working, because one of the bleeder holes on the top of the control box shoots out oil. I have checked the fluid level and it appears to be fine. There are times where The hydraulics lift the blade and it will hold it up and another time it will lift it and slowly sink down. Another problem I notice about the control lever is that it gets stuck when ever I try to activate the up and down lever. It is like some thing is bound inside. I have taken the return line to the reservoir off and proded into the control box with a piece of wire and that seems to free it up momentary. Would ice build up in the control box...We have had some warm weather up here in Northern Minnesota the past couple of weekends. Thanks for any answers
Dan
Dean Gladow
10-11-2005 10:31:13
 Re: Monarch snowplow hydraulic pump on tractor in reply to Dan of Minnesota, 02-26-2005 07:20:27
I found this site and discussion while trying to identify the Monarch Dyna Might unit which was being advertised on eBay. It didn't receive any bids, so should still be available if anyone wants to contact the seller. Item number was 7551685417, and by going to it, you can contact the seller.
dr.sportster
02-27-2005 04:52:09
Dan,If the arm ever breaks on yours let me now I can make you a new one.Mine snapped[its cast al]I just replaced it with a piece of billet.Takes about twenty minutes to drill and tap anew one.If yours breaks just post about it here to contact me.
can't use my reserved nam
02-26-2005 13:22:25
Hi
if you think freezing is possibly the problem; warm it up inside shed and then put a couple bottles of the best heet or similar deicer you can find in the hydralic tank and run it..if ice is the problem this will clear it up--I too am in Mn and have mositure problems in hydralics once in awhile
Mike
dr.sportster
02-26-2005 12:41:19
Hey Dan ,I have the same set up on my Farmall A.Monarch road equipment in the casting.The only times I had problems was due to belt slippage [under load].All i can say is observe the belt while another guy operates the control rod.Its also good to use a shorter belt in some cases to keep the unit tucked in to the machine.It is also my generator belt so if it slips charging on ammeter will show it some too.I hope my simple answer helps you solve a simple problem.Tightening a belt is simple after that I have no answer.Good Luck.
DaveInMI
02-26-2005 12:39:00
Before I changed the oil in my hydraulics it seemed like some moisture was turning to ice in the valve. I could leave a trouble light on the valve over night and it worked fine the next day.
