Tractor Talk Discussion Forum
Zenith carb
Brian Girard
02-25-2005 14:03:39
Thanks MJ for the info. Now, I need to know where I can get a rebuild kit or rebuild carb . The chart that MJ sent me says the model # is a 10091A and in the chart the part# is a 5367. Can anyone tell me where I can purchase these or cross reference something to get them. I hope that another tractor uses the same carb. Thanks, Brian
NC Wayne
02-25-2005 18:08:58
 Re: Zenith carb in reply to Brian Girard, 02-25-2005 14:03:39
Your best bet is to contact Zenith directly. They can tell you who is the nearest distrubutor to you. They can also check their inventory for you and tell you if a kit is available at the factory in case the distrubutor doesn't have one in stock. I've been in the same boat you are several times ovet the past few years where I needed to identify an old carb and what kit went with it and the folks at Zenith have always been more than happy to help and answer any questions I had. They can usually even go so far as to be able to pull the print for a carb if you need it. Several weeks back I needed some info on the carb on about a 1956 year model D8 CAT and the lady was able to get a print for me even back that far. Here is a link to their web site. Good luck.
Brian Girard
02-25-2005 23:33:40
 Re: Zenith carb in reply to NC Wayne, 02-25-2005 18:08:58
Thanks NC Wayne. I'm sure glad there a people out there that a truly helpful. Its people like you that make this hobby so enjoyable. Thanks again, Brian
