Tractor Talk Discussion Forum
IH 656 Battery Overheating Problem ?
jhanson
02-20-2005 14:10:11
I had an older battery in this tractor and have been recharging it over the past couple years. Yesterday it was completly dead and I noticed when I attempted to recharge it pop a cap and the battery was boiling. I bought a new one and tractor started fine. I used it about 20 minutes and then I could spell sulfur or acid. This new battery was very hot and boiling also. Any ideas on the problem - electical overload somewhere ?
Hugh MacKay
02-20-2005 14:57:28
 Re: IH 656 Battery Overheating Problem ? in reply to jhanson, 02-20-2005 14:10:11
jhanson: No question your system is over charging. Check as bo told you.
bo
02-20-2005 14:33:46
measure the charging voltage at the battery terminals with the tractor running. Use a multimeter and you should read 13-14.5 volts...any more than that and the voltage regulator gave up the ghost.
RayP(MI)
02-20-2005 18:02:16
 Re: IH 656 Battery Overheating Problem ? in reply to bo, 02-20-2005 14:33:46
And shut her down as soon as you get that voltage reading. Batteries in this situation have been known to go BOOOOOM!
83Jim
02-21-2005 07:26:41
 Re: IH 656 Battery Overheating Problem ? in reply to RayP(MI), 02-20-2005 18:02:16
Check the ground connections in and around the generator/alternator and regulator.
The last time I had this problem it was caused by a loose ground on the internal regulator of an alternator.
This causes the unit to sense low voltage and continue to charge even though the battery is fully charged.
Good luck.
