Tractor Talk Discussion Forum
firing order?
Troy in Wa
02-15-2005 20:06:44
I have a 1928 cat22 with a Eisemann C-4 I went and messed up my firing order and don"t have any means of righting my wrong.Where can I get a manual?What is the firing order?
geok
02-16-2005 18:21:00
 Re: firing order? in reply to Troy in Wa, 02-15-2005 20:06:44
Most older engine has the firing order on the block or manifold.
brianh
02-16-2005 04:04:22
Get four corks or stoppers that are the same diameter as the spark plugs. Pull all four spark plugs and insert the corks. Crank the engine slowly and note what order the corks blow out. Brian
RAB
02-17-2005 07:50:16
 Re: firing order? in reply to brianh, 02-16-2005 04:04:22
Or look at the valve gear as you turn the engine slowly in the right direction.
Regards, RAB
MLP
02-16-2005 03:57:20
I do not remember the firing order, but if you follow the link it will take you to a web site just for cat 22s. There is a copy of the operator�s book there page 23 tells the firing order on the mag.
