Tractor Talk Discussion Forum
Advice on transferring hydraulic fluid
bigblue
02-14-2005 18:55:57
Any suggestions on make or what type of hand pump to get for moving hydraulic fluid from buckets to tractor or pumping fluid out of tractor into buckets?
Had my fill of getting fluid all over the place and lifting heavy buckets.
Thanks.
Rod in Smiths Falls, ON,
02-15-2005 04:44:51
 Re: Advice on transferring hydraulic fluid in reply to bigblue, 02-14-2005 18:55:57
Emptying one of those five gallon containers into a tractor couldn't be much simpler. I discovered that a piece of sump pump hose twists right on to the pouring spout. All I did was set the container on the hood or tractor seat, direct the hose down into the tranny through the hole, and let'er rip. Gravity sure works with this stuff.
J. Schwiebert
02-15-2005 03:19:36
T-Bone has the best advice with the electric pump with Filter. New hydraulic oil is not clean.
Running it through a 10 micron filter will help your hydraulic systems live longer. In fact I know of one system where the only way you can add hydraulic fluid is to attach the supply to a port that has a 3 micron filter with it so it has to be a pressure pump.
Gregg
02-14-2005 20:18:19
Get a transfer pump , it looks like a grease gun with 2 hoses on one end. Pull plunger and it fills up and push plunger to empty. From tractor to drum or from drum to tractor ,easy and not very expensive. In canada can be purchased at Princess Auto
old
02-14-2005 19:10:35
I don't know the brand but I picked one up at an Orielly's auto parts house a few years ago for around $50-60 and have loved it.
bigblue
02-14-2005 19:36:03
 Re: Advice on transferring hydraulic fluid in reply to old, 02-14-2005 19:10:35
Was it a rotary pump or lever pump?
old
02-14-2005 19:40:40
 Re: Advice on transferring hydraulic fluid in reply to bigblue, 02-14-2005 19:36:03
Lever pump, you pull the lid from the bucket and the metal top screws on the bucket with 3 wing nut bolts.
T_Bone
02-15-2005 02:27:20
 Re: Advice on transferring hydraulic fluid in reply to old, 02-14-2005 19:40:40
Hi BB,
Or you can look at the 12v SurFlo Vitone(seal type) pumps as they will pump diesel/oils. Rated at 2.8gpm@35psi and comes with a pressure switch for about $80. The 1.5gpm pump, about $60.
There a diaphram pump so there good for flamable liquids.
The Surflo pumps are the same pumps you buy for RV's water pumps so all RV supply co's carry them.
I have one on my diesel transfer tank that I use with a 12v lawn & garden battery. With two fuel filters, one 10micron, one 2micron in series, I get about 1.2gpm flow.
T_Bone
